PMS crashing after a few hours
i use a synology DS916+, latest DSM 6.1.5-15254,
and plex version 1.11.3.4803
my plex is crashing…meaning that it stop working…!
so if i try to stop it and relaunch… it doesn’t work.; it seems the only way is to restart my synology server
i attach the log… maybe it is because of this error it stops functionning.
Thank you for the logs.
Your DiskStation cannot reach the internet. PMS eventually fails because of this. I cannot download the required files.
The error in your log shows
Plex Media Server.3.log:Feb 16, 2018 21:25:45.652 [0x7f9e50167700] ERROR - OCSP response error: -6
Plex Media Server.4.log:Feb 16, 2018 21:25:43.508 [0x7f9e52d59700] ERROR - Error issuing curl_easy_perform(handle): 6
Plex Media Server.4.log:Feb 16, 2018 21:25:43.510 [0x7f9e52d59700] ERROR - Error issuing curl_easy_perform(handle): 6
Plex Media Server.4.log:Feb 16, 2018 21:25:43.548 [0x7f9e4f511700] ERROR - Error issuing curl_easy_perform(handle): 6
Plex Media Server.4.log:Feb 16, 2018 21:25:43.549 [0x7f9e4f511700] ERROR - Error issuing curl_easy_perform(handle): 6
Plex Media Server.4.log:Feb 16, 2018 21:25:43.567 [0x7f9e49559700] ERROR - Error issuing curl_easy_perform(handle): 6
Plex Media Server.4.log:Feb 16, 2018 21:25:43.568 [0x7f9e49559700] ERROR - Error issuing curl_easy_perform(handle): 6
[chuck@lizum user.108]$
Error 6 is “DNS Lookup Failure”. The means it cannot find plex.tv by name
In Control Panel - Network examine the network settings for your ethernet adapter.
It will either be “Automatic” (DHCP) or manual.
If manual, it should point to your router / modem. It will look something like this:
Hi Trumpy
i did what you suggested… installed filebot, rename all the file…but plex is still crashing…
and when i stop the service and re start it… it doesn t work… i really need to reboot my synology server for it to work.
i attach my log…
thanks for your help
