PMS db corrupted - running in BINHEX docker on Unraid
I’m not undestanding.
Did you install on Ubuntu from the SNAP package?
sudo snap list
PRETTY_NAME=“Ubuntu 22.04.2 LTS”
NAME=“Ubuntu”
VERSION_ID=“22.04”
VERSION=“22.04.2 LTS (Jammy Jellyfish)”
VERSION_CODENAME=jammy
EDITED:
sudo snap list
no, did dpkg -i .pkg
sudo snap list
[sudo] password for mediaserver:
sudo: snap: command not found
pdkg -i .pkg ???
dpkg -l | grep -i plexm
mediaserver@mediaserver:~$ dpkg -l | grep -i plexm
ii plexmediaserver 1.32.4.7195-7c8f9d3b6 amd64 Plex organizes all of your personal media so you can easily access and enjoy it.
I thought you asked me how I installed Plex.
sudo dpkg -i plexmediaserver_1.32.4.7195-7c8f9d3b6_amd64.deb
That’s what I was trying to figure out.
Give me a moment.
There’s no way it will fail to detect PMS on Ubuntu if /var/lib/plexmediaserver exists
[chuck@lizum ~.2001]$ dpkg -l | grep plexm
ii  plexmediaserver                            1.32.2.7100-248a2daf0               amd64        Plex organizes all of your personal media so you can easily access and enjoy it.
[chuck@lizum ~.2002]$ sudo git/chuck/PlexDBRepair/DBRepair.sh
      Plex Media Server Database Repair Utility (Ubuntu 20.04.6 LTS)
                       Version v1.0.8
Select
  1 - 'stop'      - Stop PMS
  2 - 'automatic' - database check, repair/optimize, and reindex in one step.
  3 - 'check'     - Perform integrity check of database
  4 - 'vacuum'    - Remove empty space from database
  5 - 'repair'    - Repair/Optimize  databases
  6 - 'reindex'   - Rebuild database database indexes
  7 - 'start'     - Start PMS
  8 - 'import'    - Import watch history from another database independent of Plex. (risky)
  9 - 'replace'   - Replace current databases with newest usable backup copy (interactive)
 10 - 'show'      - Show logfile
 11 - 'status'    - Report status of PMS (run-state and databases)
 12 - 'undo'      - Undo last successful command
 99 - 'quit'      - Quit immediately.  Keep all temporary files.
      'exit'      - Exit with cleanup options.
Enter command # -or- command name (4 char min) :
I will reinstall plex over my previous version.
Works now. Thank you.
For some reason, /var/lib/plexmediaserver was not found.
Don’t shutdown PMS while doing first-level Optimization ?
how do I do that ? what option is it ?
If you have PMS optimize itself – it must be running (obviously).
Now that you have things recognized again.
From within the tool
  1. Stop PMS
  2. Auto
  3. Start
  4. Exit
should I ignore this ?
channel 4: open failed: connect failed: Connection refused
a few of them
root@mediaserver:/home/mediaserver/PlexDBRepair# ./DBRepair.sh
      Plex Media Server Database Repair Utility (Ubuntu 22.04.2 LTS)
                       Version v1.0.8
Select
Enter command # -or- command name (4 char min) : 1
Stopping PMS.
Stopped PMS.
Select
Enter command # -or- command name (4 char min) : 2
Automatic Check,Repair,Index started.
Checking the PMS databases
Check complete.  PMS main database is OK.
Check complete.  PMS blobs database is OK.
Exporting current databases using timestamp: 2023-06-17_23.42.22
Exporting Main DB
Exporting Blobs DB
channel 3: open failed: connect failed: Connection refused
Successfully exported the main and blobs databases.  Proceeding to import into new databases.
Importing Main DB.
Importing Blobs DB.
Successfully imported databases.
Verifying databases integrity after importing.
Verification complete.  PMS main database is OK.
Verification complete.  PMS blobs database is OK.
Saving current databases with '-BACKUP-2023-06-17_23.42.22'
Making repaired databases active
Repair complete. Please check your library settings and contents for completeness.
Recommend:  Scan Files and Refresh all metadata for each library section.
Backing up of databases
Backup current databases with '-BACKUP-2023-06-17_23.44.12' timestamp.
Reindexing main database
Reindexing main database successful.
Reindexing blobs database
Reindexing blobs database successful.
Reindex complete.
Automatic Check, Repair/optimize, & Index successful.
Select
Enter command # -or- command name (4 char min) : 7
Starting PMS.
Started PMS
Select
Running Plex behind a proxy.
The tool does not care about a proxy.
It only cares about console connectivity to you (the command line).
So these connection failed are fine?
You did a port forward/tunnel as you connected to the command line?
ssh -L
Channel 3 and 4 are used for SSH tunnel / port forwarding inside the SSH connection.
(common when SSH to a remote PMS host AND forwarding port 32400)
yes I did
Then don’t worry about it.
Thank you so much, I really appreciate it.
anytime!
(you happened to catch me still awake & folding laundry. hahaha)
