Would it be possible to get some help with -[Req#a34/Database optimization/com.plexapp.plugins.libra
Server Version#:1.32.3.7089-7000
Player Version#:Beta
Would anyone be able to help me with this error I get while optimizing?
[Req#a34/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x7f995e7100, 17, statement aborts at 58: [select * from metadata_items limit 1] database schema has changed
Everything runs fine. It’s just slow and I would like to optimize it.
If I have to start over, can I keep my thumbnails, playlists and collections?
Plex Media Server Logs_2023-05-30_23-26-03.zip (5.0 MB)
Thanks!
Can you handle a little command line work with Putty/SSH into the synology command line ?
I have not done it before. Are the directions good? If they are, I can try and pull it off! I’ll try anything!
Would I install the github server and download the software through that?
don’t overcomplicate it.
download the file using your browser.
copy it to the NAS
I show where to put it and then what to do in the README.md
(hint: Put it at the very top of the Plex or PlexMediaServer shared folder)
Im going to try it now!
Hi
I did everything and it was successful! or “ok”! I like to be pushed out of my comfort zone. I had not done that before and now I have a “little” better understanding of what goes on behind the curtains! Thank you. super cool tool!
I go to run PMS and it starts to run and then quits to “manually stopped”. I have tried to hit run like 6 times and it wont work. I removed the repair tool files after the first fail. Do i need to redo iit?
Thanks again
Mike
@ChuckPa - It’s refusing connection. I went back in through the tool and did it all again. this time I hit 7 to have it run and then “exit”.
I have checked every setting and I tried to connect locally (manually). I’m afraid to stop it for that it won’t start.
That’s telling you (in web browser fashion) the server didn’t start
Open the PlexMediaServer shared folder
Go to AppData/Plex Media Server
Right-click “Logs” → “Compress to Logs.zip”
download the zip and attach here
Logs.zip (1.5 MB)
Here you go!
Logs.zip (1.5 MB)
@mdreed72
You ran the tool as a username other than root , didn’t you?
May 31, 2023 15:02:54.229 [547855167712] DEBUG - HttpServer: Set up a thread pool with 2 threads.
May 31, 2023 15:02:54.246 [547942989856] ERROR - SQLITE3:0x7f93f2c100, 14, cannot open file at line 41714 of [a29f994989]
On DSM 7, PlexMediaServer is very fragile.
Use this procedure to reset the permissions (complete with screenshots and the commands to paste into task scheduler)
It will take time to complete.
When you receive the email of successful completion – THEN start PMS.
I ran it as my admin account. admin@192.168.1.2.
I don’t put anything in the PMS folder!
I switched up the the user settings to open up SSH. I activated the admin and then gave permissions to the shared folder. It gave me a ton of warnings about security so I changed the password of admin. I might have changed my user settings then. (I don’t think I did though).
I switched them up about 6 weeks ago when all this started. I wont again!
Ill follow
And thank you very much!
@mdreed72
Did that fix it?
FYI. ‘admin’ is NOT ‘root’ . ‘admin’ is a normal username which Synology marks with special privileges in their apps. In real Linux, it’s another non-privileged user just like ‘plex’.
You need ‘root’ when do you do this sort of thing.
No email yet. I’ll check in the morning.
Hi!
That got me back into the system!!!
I tried to optimize and got the same error. I have attached the logs. All of the DBRepair is still in the folder. Do I pull it out? Should i try the repair again?
Thank you!
Plex Media Server Logs_2023-06-01_11-40-47.zip (1.5 MB)
having this exact same issue and gave up. Tried as my personal administrator account, also tried as the synology default one (this is admin which I’ve disabled under every day use).
Either way, the db permissions get baulked and plex will not start.
thx! Glad to know it’s not a me thing. lol. I hope something we try fixes the issue!
I think maybe the problem lies in the fact we cannot use SSH as root with these devices.
You can use an admin account and raise priviliges, but this seems to leave the db with incorrect permissions after the repair.
