PMS Deleting Converted MCEBuddy files after post-processing script completes
Server Version#: 1.15.3.858, 1.15.4.919
Player Version#: 3.83.2
Since I updated PMS to version 1.15.3.858, Plex DVR has deleted the mkv file created by MCEBuddy when my post processing script runs along with the original ts file. Only the EDL file is moved, nothing else. I’ve verified MCEBuddy is not the culprit as the logs show that it successfully moved the file back into the .grab subfolder after the conversion was successful. I’ve updated to the latest Beta and the issue still exists.
Plex also seems to no longer associate the EDL files with the converted MKVs so chapters are no longer present when watching via PMP.
Likely the same as mine and other’s issue.
There seems to be a bug in the code that tries to place files within folders with the name of previously moved files. In your case, if you look at the Plex Media Server.log files, you will likely see that Plex tries to move the .mkv file into a directory with the name of the .edl file, which doesn’t exist because the .edl file is a file. So, the .mvk file just disappears.
