PMS Developer API: Search library with External ID (eg, IMDb)
After having a read through the documentation for Get Library Matches I noticed there was a field where we can supply a GUID. In the description for the method, it states we should be able to use other GUID’s such as IMDb to help with the matching, but if I supply an IMDb id, no results are returned, and if I add a title to the query all I get is whatever the title matched, even if the IMDb id is for an entirely different movie/tv show.
I’m not sure if it’s implemented yet, or I’m using it wrong but would be awesome if we could match an IMDb id directly rather than relying on a fuzzy search that may or may not return what I’m after, even if there was a way to convert IMDb Id’s into a Plex Id which we could then use would be great.
Currently i’m attempting to call it as such http://ip:port/library/matches?X-Plex-Token=token&type=1&guid=tt5052448 I’ve also tried using the guid format as imdb://movie/tt5052448 and imdb://tt5052448 but to no avail.
