If you don't mind. Can you add a quick feature enhancement to the PMS allowing reordering library sections rather than just alphabetized order. If that is too much i would even accept grouping base on categories. Thanks in advance
+1
I've been trying to find a way to do for a while now.
You can either put a numerical # a front of the section name or put the names in quotation. That should do it but its just a workaround and I don't find it neat.
+1 for this enhancement.
+1
I really would like to see this too. My home videos appear as the first item, while I only use this section a few times a year.
+1
Any updates anyone? Are the plex team going to do it?
+1 for me
+1
+1
+1
+1, alphanumeric is not working (adding numerical prefixes to each section) [PMS Windows 0.9.8.13.x] Edit: Scratch that, page reload does wonders.
Is there a way to edit the metadata for this, directly?
+1,
alphanumeric is not working (adding numerical prefixes to each section) [PMS Windows 0.9.8.13.x]Edit: Scratch that, page reload does wonders.Is there a way to edit the metadata for this, directly?
Not that i am aware of. I can't think how they relate -_-
+1
Definitely +1, this is really confusing
+1
+1
+1
yes please
