Server Version#: 1.18.9.2578-513b381af
I have a Raspberry Pi 4 4GB running Raspbian Buster fully updated, clean install with nothing else except RaspAP (wifi hotspot) installed. I followed the directions to add the Plex repository and install plexmediaserver, but when opening Plex Media Server in the Pi’s browser after install and signing in with my account info it fails after trying to start for around a minute with the message “A problem has been detected with a core component of Plex Media Server.”
Can someone help me with what is set up incorrectly?
I’ve attached my log file.Plex Media Server.5.log.txt (184.7 KB)
If it helps anyone I have a snippet of my log file, with all DEBUG lines removed, which was a very large part of the log file.
Apr 02, 2020 14:31:54.679 [0xb3929450] INFO - Plex Media Server v1.18.9.2578-513b381af - Raspbian GNU/Linux PC armv7l - build: linux-armv7hf_neon debian - GMT -05:00
Apr 02, 2020 14:31:54.691 [0xb3929450] INFO - Linux version: 10 (buster), language: en-US
Apr 02, 2020 14:31:54.691 [0xb3929450] INFO - Processor Arm
Apr 02, 2020 14:31:54.691 [0xb3929450] INFO - /usr/lib/plexmediaserver/Plex Media Server
Apr 02, 2020 14:31:55.270 [0xb27fe450] ERROR - Error issuing curl_easy_perform(handle): 6
Apr 02, 2020 14:31:55.270 [0xb27fe450] WARN - HTTP error requesting GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxxd not resolve host: plex.tv)
Apr 02, 2020 14:31:55.270 [0xb27fe450] ERROR - Error parsing content.
Apr 02, 2020 14:31:55.280 [0xb27fe450] ERROR - Error parsing XML: Error parsing file.
Apr 02, 2020 14:32:03.073 [0xb6f0e010] ERROR - Transcoder: Error cleaning old transcode sessions: boost::filesystem::directory_iterator::construct: No such file or directory: "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions"
Apr 02, 2020 14:32:03.085 [0xae5fe450] ERROR - NetworkService: Couldn't join multicast group: set_option: No such device
Apr 02, 2020 14:32:03.085 [0xae5fe450] ERROR - Error broadcasting message: send_to: Network is unreachable
Apr 02, 2020 14:32:03.086 [0xae5fe450] ERROR - NetworkService: Couldn't join multicast group: set_option: No such device
Apr 02, 2020 14:32:03.110 [0xacdfb450] ERROR - Error issuing curl_easy_perform(handle): 6
Apr 02, 2020 14:32:03.110 [0xacdfb450] WARN - HTTP error requesting GET https://plex.tv/api/v2/user/privacy?X-Plex-Token=xxxxxxxxxxxxxxxxxxxxd not resolve host: plex.tv)
Apr 02, 2020 14:32:03.126 [0xacdfb450] ERROR - Error issuing curl_easy_perform(handle): 6
Apr 02, 2020 14:32:03.126 [0xacdfb450] WARN - HTTP error requesting GET https://plex.tv/api/v2/release_channels?X-Plex-Token=xxxxxxxxxxxxxxxxxxxxd not resolve host: plex.tv)
Apr 02, 2020 14:32:03.183 [0xacdfb450] ERROR - Error issuing curl_easy_perform(handle): 6
Apr 02, 2020 14:32:03.183 [0xacdfb450] WARN - HTTP error requesting GET https://plex.tv/api/v2/features?X-Plex-Token=xxxxxxxxxxxxxxxxxxxxd not resolve host: plex.tv)
Apr 02, 2020 14:32:03.188 [0xb0dfd450] ERROR - Error issuing curl_easy_perform(handle): 6
Apr 02, 2020 14:32:03.188 [0xb0dfd450] WARN - HTTP error requesting GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxxd not resolve host: plex.tv)
Apr 02, 2020 14:32:03.188 [0xb0dfd450] ERROR - Error parsing content.
Apr 02, 2020 14:32:03.188 [0xb0dfd450] ERROR - Error parsing XML: Error parsing file.
Apr 02, 2020 14:32:03.189 [0xacdfb450] ERROR - Error issuing curl_easy_perform(handle): 6
Apr 02, 2020 14:32:03.189 [0xacdfb450] WARN - HTTP error requesting POST https://plex.tv/devices/330333bce1439c759f36f623df443cce3ca6bf80/unclaimed? (0, No error) (Could not resolve host: plex.tv)
Apr 02, 2020 14:32:06.127 [0xabdf9450] ERROR - Error issuing curl_easy_perform(handle): 6
Apr 02, 2020 14:32:06.130 [0xb0dfd450] ERROR - Error issuing curl_easy_perform(handle): 6
Apr 02, 2020 14:32:08.082 [0xabdf9450] WARN - NetworkServiceBrowser: Error sending out discover packet from 127.0.0.1 to 127.255.255.255: Operation not permitted
Apr 02, 2020 14:32:08.082 [0xb0dfd450] WARN - NetworkServiceBrowser: Error sending out discover packet from 127.0.0.1 to 127.255.255.255: Operation not permitted
Apr 02, 2020 14:32:10.466 [0xae5fe450] ERROR - Network Service: Error in browser handle read: 125 (Operation canceled) socket=-1
Apr 02, 2020 14:32:10.469 [0xaddfd450] ERROR - getaddrinfo(10-3-141-1.abcdefghijklmnopqrstuvwxyz012345.plex.direct) failed: -3
Apr 02, 2020 14:32:10.566 [0xae5fe450] INFO - Network Service: Abandoning browse socket, it was closed.
Apr 02, 2020 14:32:10.566 [0xae5fe450] ERROR - Network Service: Error in browser handle read: 125 (Operation canceled) socket=-1
Apr 02, 2020 14:32:10.666 [0xae5fe450] INFO - Network Service: Abandoning browse socket, it was closed.
Apr 02, 2020 14:32:10.667 [0xae5fe450] ERROR - Network Service: Error in browser handle read: 125 (Operation canceled) socket=-1
Apr 02, 2020 14:32:10.767 [0xae5fe450] INFO - Network Service: Abandoning browse socket, it was closed.
Apr 02, 2020 14:32:10.767 [0xae5fe450] ERROR - Network Service: Error in browser handle read: 125 (Operation canceled) socket=-1
Apr 02, 2020 14:32:10.867 [0xae5fe450] INFO - Network Service: Abandoning browse socket, it was closed.
Apr 02, 2020 14:32:12.466 [0xae5fe450] ERROR - Network Service: Error in browser handle read: 125 (Operation canceled) socket=-1
Apr 02, 2020 14:32:12.566 [0xae5fe450] INFO - Network Service: Abandoning browse socket, it was closed.
Apr 02, 2020 14:32:12.566 [0xae5fe450] ERROR - Network Service: Error in browser handle read: 125 (Operation canceled) socket=-1
Apr 02, 2020 14:32:12.666 [0xae5fe450] INFO - Network Service: Abandoning browse socket, it was closed.
Apr 02, 2020 14:32:12.666 [0xae5fe450] ERROR - Network Service: Error in browser handle read: 125 (Operation canceled) socket=-1
Apr 02, 2020 14:32:12.766 [0xae5fe450] INFO - Network Service: Abandoning browse socket, it was closed.
Apr 02, 2020 14:32:12.766 [0xae5fe450] ERROR - Network Service: Error in browser handle read: 125 (Operation canceled) socket=-1
Apr 02, 2020 14:32:12.867 [0xae5fe450] INFO - Network Service: Abandoning browse socket, it was closed.
Apr 02, 2020 14:32:12.867 [0xae5fe450] ERROR - Network Service: Error in browser handle read: 125 (Operation canceled) socket=-1
Apr 02, 2020 14:32:12.967 [0xae5fe450] INFO - Network Service: Abandoning browse socket, it was closed.
Apr 02, 2020 14:32:12.967 [0xae5fe450] ERROR - Network Service: Error in browser handle read: 125 (Operation canceled) socket=-1
Apr 02, 2020 14:32:13.067 [0xae5fe450] INFO - Network Service: Abandoning browse socket, it was closed.
Apr 02, 2020 14:32:13.067 [0xae5fe450] ERROR - Network Service: Error in browser handle read: 125 (Operation canceled) socket=-1
Apr 02, 2020 14:32:13.167 [0xae5fe450] INFO - Network Service: Abandoning browse socket, it was closed.
Apr 02, 2020 14:35:07.699 [0xa85f2450] INFO - AutoUpdate: no updates available
Apr 02, 2020 14:35:08.287 [0xabdf9450] INFO - AutoUpdate: no updates available
Apr 02, 2020 14:35:48.303 [0xaadf7450] ERROR - Timeout or error reading status line from plug-in pipe [tv.plex.agents.music], we're killing it.
Apr 02, 2020 14:35:48.303 [0xaadf7450] ERROR - Error received reading configuration for tv.plex.agents.music
Apr 02, 2020 14:35:48.303 [0xaa5f6450] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.none], we're killing it.
Apr 02, 2020 14:35:48.303 [0xaa5f6450] ERROR - Error received reading configuration for com.plexapp.agents.none
Apr 02, 2020 14:35:48.305 [0xab5f8450] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.movieposterdb], we're killing it.
Apr 02, 2020 14:35:48.305 [0xab5f8450] ERROR - Error received reading configuration for com.plexapp.agents.movieposterdb
Apr 02, 2020 14:35:48.310 [0xb2fff450] WARN - JobManager: Could not find job for handle 1245
Apr 02, 2020 14:35:48.311 [0xb2fff450] WARN - JobManager: Could not find job for handle 1243
Apr 02, 2020 14:35:48.312 [0xb2fff450] WARN - JobManager: Could not find job for handle 1240
Apr 02, 2020 14:38:48.351 [0xaa5f6450] ERROR - Timeout or error reading status line from plug-in pipe [org.musicbrainz.agents.music], we're killing it.
Apr 02, 2020 14:38:48.351 [0xaa5f6450] ERROR - Error received reading configuration for org.musicbrainz.agents.music
Apr 02, 2020 14:38:48.361 [0xb2fff450] WARN - JobManager: Could not find job for handle 1742
Apr 02, 2020 14:38:48.411 [0xaadf7450] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.plexthememusic], we're killing it.
Apr 02, 2020 14:38:48.411 [0xaadf7450] ERROR - Error received reading configuration for com.plexapp.agents.plexthememusic
Apr 02, 2020 14:38:48.417 [0xab5f8450] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.fanarttv], we're killing it.
Apr 02, 2020 14:38:48.418 [0xab5f8450] ERROR - Error received reading configuration for com.plexapp.agents.fanarttv
Apr 02, 2020 14:38:48.425 [0xb2fff450] WARN - JobManager: Could not find job for handle 1740
Apr 02, 2020 14:38:48.431 [0xb2fff450] WARN - JobManager: Could not find job for handle 1737
Apr 02, 2020 14:41:34.471 [0xa53fb450] INFO - AutoUpdate: no updates available
Apr 02, 2020 14:41:35.044 [0xa85f2450] INFO - AutoUpdate: no updates available
Apr 02, 2020 14:41:48.452 [0xaa5f6450] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.lastfm], we're killing it.
Apr 02, 2020 14:41:48.452 [0xaa5f6450] ERROR - Error received reading configuration for com.plexapp.agents.lastfm
Apr 02, 2020 14:41:48.457 [0xb2fff450] WARN - JobManager: Could not find job for handle 1892
Apr 02, 2020 14:41:48.521 [0xab5f8450] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.imdb], we're killing it.
Apr 02, 2020 14:41:48.521 [0xab5f8450] ERROR - Error received reading configuration for com.plexapp.agents.imdb
Apr 02, 2020 14:41:48.526 [0xb2fff450] WARN - JobManager: Could not find job for handle 1896
Apr 02, 2020 14:41:48.540 [0xaadf7450] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.thetvdb], we're killing it.
Apr 02, 2020 14:41:48.540 [0xaadf7450] ERROR - Error received reading configuration for com.plexapp.agents.thetvdb
Apr 02, 2020 14:41:48.551 [0xb2fff450] WARN - JobManager: Could not find job for handle 1899
Apr 02, 2020 14:43:16.758 [0xb2fff450] WARN - Timed out waiting for server to finish.
Apr 02, 2020 14:43:16.770 [0xb2fff450] WARN - JobManager: Could not find job for handle 2088
Apr 02, 2020 14:43:16.770 [0xb2fff450] WARN - JobManager: Could not find job for handle 2092
Apr 02, 2020 14:43:16.777 [0xb2fff450] WARN - JobManager: Could not find job for handle 2084
Apr 02, 2020 14:43:16.778 [0xb2fff450] WARN - JobManager: Could not find job for handle 645
