PMS - On RPI3 does not start
Server Version#: 1.21.0.3711-b509cc236
Hi after installation, on my localhost page is " We encountered a problem with a core component of Plex Media Server."
I want to add my folders from hdd not mounted, but can’t do anything because it’s blocked
This is the first lines log:
Dec 11, 2020 01:39:44.891 [0x73c95430] INFO - Plex Media Server v1.21.0.3711-b509cc236 - Raspbian GNU/Linux PC armv7l - build: linux-armv7hf_neon debian - GMT 01:00
Dec 11, 2020 01:39:44.908 [0x73c95430] INFO - Linux version: 10 (buster), language: it-IT
Dec 11, 2020 01:39:44.908 [0x73c95430] INFO - Processor Arm
Dec 11, 2020 01:39:44.908 [0x73c95430] INFO - /usr/lib/plexmediaserver/Plex Media Server
Dec 11, 2020 01:39:45.037 [0x76f4db20] DEBUG - BPQ: [Idle] -> [Starting]
Dec 11, 2020 01:39:45.164 [0x76f4db20] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.26.0, threadsafe=1
Dec 11, 2020 01:39:45.797 [0x76f4db20] DEBUG - Running migrations. (EPG 0)
Dec 11, 2020 01:39:45.832 [0x76f4db20] DEBUG - ChangestampAllocator: initialized to 0
Dec 11, 2020 01:39:45.832 [0x76f4db20] DEBUG - Opening 2 database sessions to library (com.plexapp.plugins.library.blobs), SQLite 3.26.0, threadsafe=1
Dec 11, 2020 01:39:45.936 [0x76f4db20] DEBUG - Running migrations. (EPG 0)
Dec 11, 2020 01:39:46.091 [0x76f4db20] DEBUG - HttpServer: Listening on IPv6 as well as IPv4.
Dec 11, 2020 01:39:46.091 [0x76f4db20] DEBUG - HttpServer: Listening on port 32400.
Dec 11, 2020 01:39:46.091 [0x76f4db20] DEBUG - HttpServer: Listening on port 32401.
Dec 11, 2020 01:39:46.474 [0x72afe430] DEBUG - Job running: '/usr/lib/plexmediaserver/CrashUploader' '--directory=/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Crash Reports/1.21.0.3711-b509cc236' '--version=1.21.0.3711-b509cc236' '--platform=Linux' '--platformVersion=10 (buster)' '--serverUuid=b138714b8facfa901f36138135a4b89548d3dcac' '--userId=NOUSERID' '--sentryUrl=https://sentry.io/api/1233455/minidump' '--sentryKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx' '--vendor=Raspbian GNU/Linux' '--model=armv7l' '--device=PC' '--allowRetries=0'
Dec 11, 2020 01:39:46.482 [0x72afe430] DEBUG - Jobs: Starting child process with pid 678
Dec 11, 2020 01:39:46.555 [0x72afe430] DEBUG - Grabber: Cleaning up orphaned grabs.
Dec 11, 2020 01:39:46.557 [0x72afe430] DEBUG - Grabber: Cleaned up 0 decrepit directories in 0.0 sec.
Dec 11, 2020 01:39:46.582 [0x76f4db20] DEBUG - Media Provider: Registering provider com.plexapp.plugins.library
Dec 11, 2020 01:39:46.599 [0x72afe430] DEBUG - MyPlex: mapping state set to 'Unknown'.
Dec 11, 2020 01:39:46.635 [0x72afe430] DEBUG - Relay: read 0 cached entries from hosts file
Dec 11, 2020 01:39:46.635 [0x72afe430] DEBUG - HTTP requesting GET https://plex.tv/media/providers?X-Plex-Token=
Dec 11, 2020 01:39:46.640 [0x76f4db20] DEBUG - Auth: Refreshing tokens inside the token-based authentication filter.
Dec 11, 2020 01:39:46.641 [0x70eff430] DEBUG - Auth: Refreshing tokens inside the token-based authentication filter.
Dec 11, 2020 01:39:46.676 [0x76f4db20] DEBUG - Opening 1 database sessions to library (), SQLite 3.26.0, threadsafe=1
Dec 11, 2020 01:39:46.706 [0x732ff430] DEBUG - Jobs: '/usr/lib/plexmediaserver/CrashUploader' exit code for process 678 is 0 (success)
Dec 11, 2020 01:39:46.731 [0x702ff430] DEBUG - File "/usr/lib/plexmediaserver/Resources/Plug-ins-b509cc236" changed: -1 => 2020-12-07 00:57:47 (1607299067).
Dec 11, 2020 01:39:46.731 [0x702ff430] DEBUG - File "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins" changed: -1 => 2020-12-07 01:05:57 (1607299557).
Dec 11, 2020 01:39:46.731 [0x702ff430] DEBUG - Scanning for plug-ins in "/usr/lib/plexmediaserver/Resources/Plug-ins-b509cc236"
Dec 11, 2020 01:39:47.134 [0x702ff430] DEBUG - Scanning for plug-ins in "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins"
Dec 11, 2020 01:39:47.136 [0x702ff430] DEBUG - PluginRepository::setStartState: 1, startingSystem
Dec 11, 2020 01:39:47.136 [0x702ff430] DEBUG - Starting plug-in /usr/lib/plexmediaserver/Resources/Plug-ins-b509cc236/System.bundle.
Dec 11, 2020 01:39:47.139 [0x702ff430] DEBUG - [com.plexapp.system] Setting plug-in to always running (daemon mode).
Dec 11, 2020 01:39:47.151 [0x702ff430] DEBUG - Starting file watcher for com.plexapp.system
Dec 11, 2020 01:39:47.151 [0x702ff430] DEBUG - Plugin: not setting user token for plugin
Dec 11, 2020 01:39:47.154 [0x702ff430] DEBUG - Spawned plug-in com.plexapp.system with PID 696
Dec 11, 2020 01:39:47.154 [0x702ff430] DEBUG - [com.plexapp.system] Sending command: GET /:/prefixes
Dec 11, 2020 01:39:56.557 [0x70eff430] DEBUG - Grabber: Plex Tuner Service not running; retrying in 10 seconds.
Dec 11, 2020 01:40:04.620 [0x702ff430] DEBUG - Reading 486 bytes in the body, code is 200
Dec 11, 2020 01:40:04.620 [0x702ff430] DEBUG - [com.plexapp.system] Plug-in running on port 45129.
Dec 11, 2020 01:40:04.620 [0x702ff430] DEBUG -  * Plug-in handles prefix: /system
Dec 11, 2020 01:40:04.620 [0x702ff430] DEBUG -  * Plug-in handles prefix: /player
Dec 11, 2020 01:40:04.620 [0x702ff430] DEBUG - Read configuration for [com.plexapp.system], had 2 prefixes
Dec 11, 2020 01:40:04.621 [0x702ff430] DEBUG - Done with 1 synchronous plug-in starts, starting the rest in parallel.
Dec 11, 2020 01:40:04.621 [0x702ff430] DEBUG - PluginRepository::setStartState: 2, startingPlugins
Dec 11, 2020 01:40:04.621 [0x702ff430] DEBUG - Updating the list of agents known by the system.
Dec 11, 2020 01:40:04.621 [0x702ff430] DEBUG - [com.plexapp.system] Sending command over HTTP (GET): /system/agents
Dec 11, 2020 01:40:04.621 [0x702ff430] DEBUG - HTTP requesting GET http://127.0.0.1:45129/system/agents
Dec 11, 2020 01:40:04.634 [0x76f4db20] DEBUG - Image transcode cache directory: "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/PhotoTranscoder"
Dec 11, 2020 01:40:04.647 [0x76f4db20] DEBUG - Transcoder: Cleaning old transcode directories.
Dec 11, 2020 01:40:04.665 [0x76f4db20] DEBUG - MyPlex: stop public ip check and mapping - current mapped state: 'Unknown'.
Dec 11, 2020 01:40:04.665 [0x76f4db20] DEBUG - NetworkInterface: Starting watch thread.
Dec 11, 2020 01:40:04.666 [0x76f4db20] DEBUG - Network change.
Dec 11, 2020 01:40:04.666 [0x76f4db20] DEBUG - NetworkInterface: Notified of network changed (force=0)
Dec 11, 2020 01:40:04.666 [0x6eafc430] DEBUG - NetworkInterface: Watching for changes on the interfaces.
Dec 11, 2020 01:40:04.667 [0x76f4db20] DEBUG - Detected primary interface: 10.11.252.138
Dec 11, 2020 01:40:04.667 [0x76f4db20] DEBUG - Network interfaces:
Dec 11, 2020 01:40:04.667 [0x76f4db20] DEBUG -  * 1 lo (127.0.0.1) (loopback: 1)
Dec 11, 2020 01:40:04.667 [0x76f4db20] DEBUG -  * 2 eth0 (192.168.1.169) (loopback: 0)
Dec 11, 2020 01:40:04.667 [0x76f4db20] DEBUG -  * 1 lo (::1) (loopback: 1)
Dec 11, 2020 01:40:04.667 [0x76f4db20] DEBUG -  * 2 eth0 (fe80::d2c1:7fec:de72:44ee%eth0) (loopback: 0)
Dec 11, 2020 01:40:04.667 [0x76f4db20] DEBUG - Creating NetworkServices singleton.
Dec 11, 2020 01:40:04.668 [0x76f4db20] DEBUG - NetworkServices: Initializing...
Dec 11, 2020 01:40:04.668 [0x76f4db20] DEBUG - NetworkService: Creating new service.
Dec 11, 2020 01:40:04.668 [0x76f4db20] DEBUG - NetworkService: Got notification of changed network (first change: 1)
Dec 11, 2020 01:40:04.668 [0x76f4db20] DEBUG - NetworkService: Quick dispatch of network change.
Dec 11, 2020 01:40:04.668 [0x6e0ff430] DEBUG - Network change for advertiser.
Dec 11, 2020 01:40:04.668 [0x6e0ff430] DEBUG - NetworkService: Setting up multicast listener on 0.0.0.0:32414
Dec 11, 2020 01:40:04.669 [0x76f4db20] DEBUG - NetworkService: Creating new service.
Dec 11, 2020 01:40:04.669 [0x76f4db20] DEBUG - NetworkService: Got notification of changed network (first change: 1)
Dec 11, 2020 01:40:04.669 [0x76f4db20] DEBUG - NetworkService: Quick dispatch of network change.
Dec 11, 2020 01:40:04.684 [0x70eff430] DEBUG - HTTP requesting GET https://plex.tv/api/photos/profile
Dec 11, 2020 01:40:04.691 [0x76f4db20] DEBUG - Starting HTTP server.
Dec 11, 2020 01:40:04.691 [0x76f4db20] DEBUG - Running server...
Dec 11, 2020 01:40:04.691 [0x6d0fd430] DEBUG - Plex Tuner Service starting.
Dec 11, 2020 01:40:04.691 [0x6d0fd430] DEBUG - Job running: '/usr/lib/plexmediaserver/Plex Tuner Service' '/usr/lib/plexmediaserver/Resources/Tuner/Private' '/usr/lib/plexmediaserver/Resources/Tuner/Shared' '1.21.0.3711-b509cc236' '32600' '/waitmutex'
Dec 11, 2020 01:40:04.691 [0x76f4db20] DEBUG - Waiting for server condition to be signaled.
Dec 11, 2020 01:40:04.691 [0x6c8fc430] DEBUG - HttpServer: Set up a thread pool with 2 threads.
Dec 11, 2020 01:40:04.691 [0x6c8fc430] DEBUG - HTTP requesting GET https://plex.tv/api/v2/user/privacy?X-Plex-Token=
Dec 11, 2020 01:40:04.695 [0x6e0ff430] DEBUG - Network change for advertiser.
Dec 11, 2020 01:40:04.695 [0x6e0ff430] DEBUG - NetworkService: Setting up multicast listener on 0.0.0.0:32410
Dec 11, 2020 01:40:04.696 [0x6e0ff430] DEBUG - Network change for advertiser.
Dec 11, 2020 01:40:04.696 [0x6e0ff430] DEBUG - NetworkService: Setting up multicast listener on 0.0.0.0:32412
Dec 11, 2020 01:40:04.696 [0x6e0ff430] DEBUG - NetworkService: Network change for browser (polled=0), closing 0 browse sockets.
Dec 11, 2020 01:40:04.696 [0x6e0ff430] DEBUG - NetworkService: Setting up multicast listener on 0.0.0.0:32413
Dec 11, 2020 01:40:04.697 [0x6e0ff430] DEBUG - NetworkService: Browsing on interface 127.0.0.1 on broadcast address 127.255.255.255 (index: 0)
Dec 11, 2020 01:40:04.697 [0x6e0ff430] DEBUG - NetworkService: Browsing on interface 192.168.1.169 on broadcast address 192.168.1.255 (index: 1)
Dec 11, 2020 01:40:04.697 [0x6e0ff430] DEBUG - NetworkService: Network change for browser (polled=1), closing 0 browse sockets.
Dec 11, 2020 01:40:04.697 [0x6e0ff430] DEBUG - NetworkService: Network change for browser (polled=0), closing 0 browse sockets.
Dec 11, 2020 01:40:04.697 [0x6e0ff430] DEBUG - NetworkService: Setting up multicast listener on 0.0.0.0:1901
Dec 11, 2020 01:40:04.697 [0x6e0ff430] DEBUG - NetworkService: Browsing on interface 192.168.1.169 on broadcast address 239.255.255.250 (index: 0)
Dec 11, 2020 01:40:04.698 [0x6d0fd430] DEBUG - Jobs: Starting child process with pid 2163
Dec 11, 2020 01:40:04.766 [0x6eafc430] DEBUG - NetworkInterface: received Netlink message len=88, type=RTM_DELADDR, flags=0x0
Dec 11, 2020 01:40:04.766 [0x6eafc430] DEBUG - NetworkInterface: Netlink address message family=2, index=2, flags=0x80
Dec 11, 2020 01:40:04.766 [0x6eafc430] DEBUG - Network change.
Dec 11, 2020 01:40:04.766 [0x6eafc430] DEBUG - NetworkInterface: Notified of network changed (force=0)
Dec 11, 2020 01:40:04.767 [0x6eafc430] DEBUG - Network change notification but nothing changed.
Dec 11, 2020 01:40:04.886 [0x6eafc430] DEBUG - NetworkInterface: received Netlink message len=88, type=RTM_DELADDR, flags=0x0
Dec 11, 2020 01:40:04.887 [0x6eafc430] DEBUG - NetworkInterface: Netlink address message family=2, index=2, flags=0x80
Dec 11, 2020 01:40:04.887 [0x6eafc430] DEBUG - Network change.
Dec 11, 2020 01:40:04.887 [0x6eafc430] DEBUG - NetworkInterface: Notified of network changed (force=0)
Dec 11, 2020 01:40:04.888 [0x6eafc430] DEBUG - Network change notification but nothing changed.
Dec 11, 2020 01:40:05.038 [0x6eafc430] DEBUG - NetworkInterface: received Netlink message len=88, type=RTM_DELADDR, flags=0x0
Dec 11, 2020 01:40:05.038 [0x6eafc430] DEBUG - NetworkInterface: Netlink address message family=2, index=2, flags=0x80
Dec 11, 2020 01:40:05.038 [0x6eafc430] DEBUG - Network change.
Dec 11, 2020 01:40:05.038 [0x6eafc430] DEBUG - NetworkInterface: Notified of network changed (force=0)
Dec 11, 2020 01:40:05.040 [0x6eafc430] DEBUG - Network change notification but nothing changed.
Dec 11, 2020 01:40:05.170 [0x6eafc430] DEBUG - NetworkInterface: received Netlink message len=88, type=RTM_DELADDR, flags=0x0
Dec 11, 2020 01:40:05.170 [0x6eafc430] DEBUG - NetworkInterface: Netlink address message family=2, index=2, flags=0x80
Dec 11, 2020 01:40:05.170 [0x6eafc430] DEBUG - Network change.
Dec 11, 2020 01:40:05.170 [0x6eafc430] DEBUG - NetworkInterface: Notified of network changed (force=0)
Dec 11, 2020 01:40:05.171 [0x6eafc430] DEBUG - Network change notification but nothing changed.
Dec 11, 2020 01:40:05.321 [0x6eafc430] DEBUG - NetworkInterface: received Netlink message len=88, type=RTM_DELADDR, flags=0x0
Dec 11, 2020 01:40:05.321 [0x6eafc430] DEBUG - NetworkInterface: Netlink address message family=2, index=2, flags=0x80
Dec 11, 2020 01:40:05.321 [0x6eafc430] DEBUG - Network change.
Dec 11, 2020 01:40:05.321 [0x6eafc430] DEBUG - NetworkInterface: Notified of network changed (force=0)
Dec 11, 2020 01:40:05.322 [0x6eafc430] DEBUG - Network change notification but nothing changed.
Dec 11, 2020 01:40:05.502 [0x6eafc430] DEBUG - NetworkInterface: received Netlink message len=88, type=RTM_DELADDR, flags=0x0
Dec 11, 2020 01:40:05.502 [0x6eafc430] DEBUG - NetworkInterface: Netlink address message family=2, index=2, flags=0x80
Dec 11, 2020 01:40:05.502 [0x6eafc430] DEBUG - Network change.
Dec 11, 2020 01:40:05.502 [0x6eafc430] DEBUG - NetworkInterface: Notified of network changed (force=0)
Dec 11, 2020 01:40:05.504 [0x6eafc430] DEBUG - Network change notification but nothing changed.
Dec 11, 2020 01:40:05.650 [0x6eafc430] DEBUG - NetworkInterface: received Netlink message len=88, type=RTM_DELADDR, flags=0x0
Dec 11, 2020 01:40:
05.650 [0x6eafc430] DEBUG - NetworkInterface: Netlink address message family=2, index=2, flags=0x80
Dec 11, 2020 01:40:05.650 [0x6eafc430] DEBUG - Network change.
Dec 11, 2020 01:40:05.650 [0x6eafc430] DEBUG - NetworkInterface: N
