I setup plex to work through a reverse proxy, so I can access plex at www.testdomain.com/web, and I set the custom domain in Settings > Network > Custom server access URLs to the matching domain. When I attempt to connect to that domain (https://testdomain.com/web) I get
using either of the “allow insecure connection” doesn’t fix the issue. the reverse proxy works for all other docker containers on the server without any issues. I will include server logs and logs of the web client connecting through https://testdomain.com/web
all help is appreciated, thanks!
-Milkbone
Server Version#: 1.14.1.5488 (installed VIA Docker)
Player Version#: 3.77.4
plex-logs.zip (2.1 MB)
