PMS Migration - Linux
Hey guys , pretty noobish question , but never needed to , ive outgrown my plex server and need to migrate to a More powerful server, had a Ridiculous library very large don’t want to start my new server from scratch having to re-do all meta data and library’s ect, how can i export all of plex from Ubuntu 18.04 lts ,
i will then be re-importing to ubuntu 18.04 lts , ive been looking on forums and videos “YouTube” but can only find windows migrations no Linux sadly , help would be massively appreciated
It’s going to be hysterically simple:
  1. Replicate the /etc/fstab media mounts from the first on the second.
  2. Install Plex ( plex.tv/downloads ) but don’t open it. This creates the user , services, and directory.
  3. Stop Plex. (fresh installs automatically start
  4. Go to the original system
  5. Stop Plex
  6. cd /var/lib/plexmediaserver
  7. sudo tar cf /path/to/somewhere/PlexClone.tar ./Library
  8. When it finishes, take it to the new system.
  9. Decommission the original (delete Preferences.xml at absolute minimum)
On the new.
  1. Verify user plex:plex (or ‘other’) can read the media
  2. cd /var/lib/plexmediaserver
  3. sudo mv Library Library.unused
  4. sudo tar xf /path/to/PlexClone.tar (the file you brought over from the original)
  5. sudo chown -R plex:plex ./Library
  6. sudo rm -rf Library.unused (you don’t need it now)
If you’ve got all the mounts and permissions correct,
sudo systemctl start plexmediaserver
It will spin up and resume as if nothing ever happened.
@ChuckPa thanks ill give it a go hopefully it works
sorry for the noobish question
just a matter of copy and paste from your commands?
thanks for them detailed commands
Pretty much just a copy/paste. (except for where the PlexClone.tar file is going to be written)
While copy/paste is the easy way… May I recommend you understand what each is doing so next time you can think your way through it?
hint: man command (e.g. man tar – to see all the documentation about tar)
We’re here to help with Plex on Linux but there aren’t enough hours to teach linux nor are we staffed for it.
haha of course plexclone wont exsist im not that bad at linux lol
damm its giving a error
my paths normal?
@ChuckPa
You can copy/paste text here. It’s a lot easier to read that way.
This is what you should have when done
[chuck@lizum plexmediaserver.587]$ ls -la
total 16
drwxr-xr-x  4 plex plex 4096 Jan 16 23:16 ./
drwxr-xr-x 77 root root 4096 Dec 15 22:17 ../
drwxr-xr-x  3 plex plex 4096 Dec  1 09:15 Library/
drwxr-xr-x  2 plex plex 4096 Jan 16 23:16 Library.unused/
[chuck@lizum plexmediaserver.588]$ ll Library
total 12
drwxr-xr-x 3 plex plex 4096 Dec  1 09:15 ./
drwxr-xr-x 4 plex plex 4096 Jan 16 23:16 ../
drwxr-xr-x 3 plex plex 4096 Dec  1 09:15 Application Support/
[chuck@lizum plexmediaserver.589]$
Notice threre is the Library.unused which is what the installer created. We don’t use this.
When extracting the .tar file, tar xf /path/to/PlexClone.tar, it will create Library for you and populate it with everything from the old system.
didnt get any of that :frowning:
it didnt even backup
You didn’t follow my instructions?
Steps 6 & 7 are the two key steps for capturing the “source” system data files to take to the new system.
got this , but i had a tar file from july which is over 50gb so dont really understand why this is so low
@ChuckPa what do you reckon
@ChuckPa was created instantly is this normal?
i was expecting it to take a while and be a much larger file
There’s a HUGE difference between those two.
5 MB tar file is indeed nearly instantaneous.
Did you create that tar file on the system you’re copying FROM ?
hi @ChuckPa i created it on the original system yes
How are you creating it?
The screenshots you’re showing look like you’re using a windows tool?
Is that correct?
Everything I’m giving you should be done on the Linux “Terminal” command line.
How skilled are you with Linux?
that screenshot was so i could see the size of the File in Filezilla ,
everything else is done in linux
The ls command will show you everything.
[chuck@lizum ~.592]$ ls -la *.tar
-rw-r--r--. 1 chuck chuck   276480 Jun 16  2019 Debian-Packaging-files.tar
-rw-r--r--. 1 chuck chuck    92160 Aug  9  2019 debian.tar
-rw-r--r--  1 chuck chuck 24084480 Feb 23  2020 DOT-filebot.tar
-rw-r--r--. 1 chuck chuck   460800 Feb  1  2018 redhat-ci.tar
[chuck@lizum ~.593]$ ls -lah *tar
-rw-r--r--. 1 chuck chuck 270K Jun 16  2019 Debian-Packaging-files.tar
-rw-r--r--. 1 chuck chuck  90K Aug  9  2019 debian.tar
-rw-r--r--  1 chuck chuck  23M Feb 23  2020 DOT-filebot.tar
-rw-r--r--. 1 chuck chuck 450K Feb  1  2018 redhat-ci.tar
[chuck@lizum ~.594]$
