Moving my libray to another system
Hello
I’m running Plex for years on Ubuntu (Kubuntu actually), usually the latest version of Ubuntu and Plex. I bougth myself a new hard drive and made a new fresh Kubuntu install. I have the old drive plugged in so I can copy my old stuff.
I’m following this: https://support.plex.tv/articles/201370363-move-an-install-to-another-system/
  • install Plex
  • copy the main Plexmedieserver (in /var/lib) folder (tried without or without Preference.xml)
  • run Plex
I tried all I could, read some threads, but it won’t work: Plex doesn’t see my old libraries/metadata. I’m not too keen to retag hundreds of files…
Any suggestion please?
Thanks for your help!
cheers,
What exactly isn’t working?
  • Does Plex start?
  • Does it show your libraries?
  • Do the libraries have the expected content?
As you’re on a Linux system… have you considered to set permissions/folder ownership?
If I may add?
If you are moving from one to another, this, along with other tips in the Linux-Tips tag, will probably be of most help
Hi Tom, Plex does start but it doesn’t show me the libraries I had on my old system.
I checked the permissions, all folders in the Plexmediaserver are plex:plex, as expected.
thanks!
thanks Chuck. I’ll give it a try. and come back. Appreciate the help.
