PMS Playlists
Server Version#: Latest
I started the server on windows 10. The previous server under linux created playlists from favorites and recently added ones. Now these lists are gone.
The playlists are generated when you install Plexamp fresh.
But you can also make them yourself. They’re normal smart playlists, generated from library filters.
I tried to make them myself but can’t find where. I have a plexamp installed. These playlists are not there either.
They are generated when you install Plexamp fresh.
Found this tool in the library. Thank you.
