How to use playlists in plexamp
I have installed PlexAmp on iOS. Can play the music fine, locally and remotely, etc. I have no playlists created on my server. When using PlexAmp however, if i select a song then create and add it to a playlist how do I find the playlist i’ve created and added the song to? If i create a playlist on the server I can see that in the PlexAmp app and use it but not the ones created in the app itself!
use your finger and swipe DOWN to refresh on the main home screen of PlexAmp… Under Recent Playlists do you see your new playlists listed?
Hi JR86, yes but its the list created on my server, not the list created from in the app!
Never mind… I deleted and reinstalled the app and it seems to be working now. Thanks anyway.
