PMS startet nach Update nicht mehr
Hallo,
ich habe heute auf die neue Version v.1.16.4.1469 geupdatet. Nach dem verlangten reboot startet PMS nicht mehr. Es startet kurz, beendet sich dann aber direkt wieder. OS ist Windows 10 (Version 1903).
Update Log:
Aug 12, 2019 10:09:12.860 [4384] INFO - Plex Update Service v1.16.4.1469-6d5612c2f - Microsoft PC x64 - build: windows-x86
Aug 12, 2019 10:09:12.860 [4384] INFO - Windows version: 6.2 (Build 9200), language de-DE
Aug 12, 2019 10:09:12.860 [4384] INFO - 8 3392 MHz processor(s): Architecture=0, Level=6, Revision=15363 Processor Identifier=Intel64 Family 6 Model 60 Stepping 3, GenuineIntel
Aug 12, 2019 10:09:12.860 [4384] DEBUG - “C:\Program Files (x86)\Plex\Plex Media Server\Plex Update Service.exe”
Aug 12, 2019 10:09:12.845 [3580] DEBUG - Main Thread
Aug 12, 2019 10:09:12.845 [3580] DEBUG - Creating UpdateService singleton
Aug 12, 2019 10:09:12.860 [4396] DEBUG - Win32Service::serviceMain: RegisterServiceCtrlHandlerEx
Aug 12, 2019 10:09:12.860 [4396] DEBUG - Win32Service::sendServiceStartPending - SERVICE_START_PENDING
Aug 12, 2019 10:09:12.860 [4396] DEBUG - Win32Service::serviceMain: Call initialize()
Aug 12, 2019 10:09:12.860 [4396] DEBUG - UpdateService::initialize: Plex Update Service
Aug 12, 2019 10:09:12.860 [4396] DEBUG - Win32Service::serviceMain: Finished initialize()
Aug 12, 2019 10:09:12.860 [4396] DEBUG - Win32Service::sendServiceRunning - SERVICE_RUNNING
Aug 12, 2019 10:09:12.860 [4396] DEBUG - Win32Service::serviceMain: Call run()
Aug 12, 2019 10:09:12.860 [4396] DEBUG - Running Plex Update Service
Aug 12, 2019 10:09:12.860 [4396] DEBUG - Listening for remote procedure calls
PMS Log:
Aug 12, 2019 10:15:09.764 [9148] INFO - Plex Media Server v1.16.4.1469-6d5612c2f - Microsoft PC x64 - build: windows-x86 windows - GMT 02:00
Aug 12, 2019 10:15:09.764 [9148] INFO - Windows version: 10.0 (Build 18362), language de-DE
Aug 12, 2019 10:15:09.764 [9148] INFO - 8 3392 MHz processor(s): Architecture=0, Level=6, Revision=15363 Processor Identifier=Intel64 Family 6 Model 60 Stepping 3, GenuineIntel
Aug 12, 2019 10:15:09.780 [7992] INFO - SQLITE3:0xe7a9b7df, 283, recovered 477 frames from WAL file C:\Users\PlexAdmin.RT\AppData\Local\Plex Media Server\Plug-in Support\Databases\com.plexapp.plugins.library.db-wal
Aug 12, 2019 10:15:09.936 [7992] INFO - SQLITE3:0xe7a9b7df, 283, recovered 748 frames from WAL file C:\Users\PlexAdmin.RT\AppData\Local\Plex Media Server\Plug-in Support\Databases\com.plexapp.plugins.library.blobs.db-wal
Aug 12, 2019 10:15:09.936 [9380] INFO - CodecManager: obtaining decoder ‘aac’
Aug 12, 2019 10:15:10.561 [9380] ERROR - Error issuing curl_easy_perform(handle): 77
Aug 12, 2019 10:15:10.561 [9380] WARN - HTTP error requesting GET https://plex.tv/api/codecs/aac_decoder?build=windows-x86-standard&deviceId=c901c4ab-80e9-492c-9aaa-8eef1ad8832d&oldestPreviousVersion=legacy&version=dd95667-2434 (0, No error) (error setting certificate verify locations:
CAfile: C:\Program Files (x86)\Plex\Plex Media Server\Resources\cacert.pem
CApath: none)
Aug 12, 2019 10:15:10.561 [9380] ERROR - Codecs: Failed to download XML for codec ‘aac_decoder’
Kann mir jemand weiter helfen? Stehe gerade etwas auf dem Schlauch.
PMS deinstallieren (ohne Einsatz von Revo, CCleaner et al)
Installationsprogramm erneut herunterladen
Installieren
Komplette Deinstallation?
Nein!
Nur Deinstallation mittels der Windows “Apps”-Systemsteuerung
Nur um sicher zu gehen.
So?
pmsdel
Genau so.
Pass auf, dass keine “Registry Cleaner” order Ă€hnliche Software im Hintergrund aktiv ist.
Über mögliche Nebenwirkungen von “Plex Service” bin ich allerdings nicht informiert.
Ich verwende persönlich NSSM fĂŒr Plex.
Funktioniert wieder alles einwandfrei!
Otto, du bist der Beste. Vielen Dank.
