PMS do not start after update
Hello,
I Update my Plex Server to 1.41.7 but i do something wrong.
My server don’t want to start.
Brought to you by linuxserver.io
To support LSIO projects visit:
https://www.linuxserver.io/donate/
GID/UID
User UID: 0
User GID: 0
Linuxserver.io version: 1.41.7.9823-59f304c16-ls267
Build-date: 2025-06-02T09:28:49+00:00
**** Server already claimed ****
Docker is used for versioning skip update check
[custom-init] No custom files found, skipping…
Starting Plex Media Server. . . (you can ignore the libusb_init error)
Connection to localhost (::1) 32400 port [tcp/] succeeded!
[ls.io-init] done.
] succeeded!
] succeeded!
After update, all work correctly but after restart the computer, i had this error.
Thanks in advance for your answer.
Where’s the IPv4 ?
Manually make a Zip of the Logs please and attach ?
I’d suggest he use the official plex docker build of Plex. Linuxserver.io had a bad build that was missing the transcoder binary a few weeks back. I personally don’t trust it not to break something.
The update change the name of my server from “PlexMediaServer” to “asus” (hostname of the computer). so maybe just need to change the setting in some files to recover the old setting.
