Server Version#: Windows7 Version 1.18.3.2111, Synology Linux: Version 1.18.3.2111
Player Version#: Player vor Windows or Mac (autoupdated) even the Webversion.
Since the last 2 versions the scanning process stucks on particular files/folders. Both on Windows and Linux PMS.
Music Librayies only. (I created a whole now library with all the fancy musicbrainz settings and I use an old library. Both stuck.)
Scanning seems to be finished, and the downloading of metadata is ongoing in the background (Altert tab), but no new files seem to be scanned.
I have moved the files/folder which are shown when it seems to be stuck, but after restarting PMS (which is the only way to get the scanning working again) the scann process stucks on other files/folders…
The log says nothing interesting.
Has this been seen by anyone here too?
What could be the cause and how could I fix it?
EDIT: I forgot to mention, that I cannot just restart the windows PMS.
A process
"C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Scanner.exe" --match --log-file-suffix " Matcher" --files @C:\temp\7ac391ee-2d33-46c2-93c0-cc98f25c5627.txt
needs to be killed, otherwise I can restart PMS, but it imediately hangs on the same file/folder.
EDIT2:
I’ve created an archive with two of the “problematic” folders.
Its on Dropbox and I can PM any supporter the link to check the files.
Hopefully they help to reproduce the stucking of the scans (which here, can be reproduced after a reboot at any time, one of the folders is in a mediafolder).
instead of
