Server Version#: 1.15.3.835
Player Version#: Web 3.93.1
I just upgraded my main boot drive from a 256 SATA SSD to a 1TB NVMe drive. Other than that, I kept my OS configuration nearly the same on Linux Mint 19.1. Plex Media Server started successfully, then I started following this guide: https://support.plex.tv/articles/201370363-move-an-install-to-another-system/
I had the old SSD mounted so as soon as I ran sudo cp -a @/var/lib/plexmediaserver/Library/Application\ Support /var/lib/plexmediaserver/Library/ and then sudo systemctl restart plexmediaserver it failed to work. I noticed that the folder wasn’t owned by plex:plex since the umask was from the old install, so I changed that with chown -R, tried restarting again, no luck.
I’d appreciate some help. At this point I might even settle for just getting it up and then letting it chug for a few hours rebuilding the metadata.
The error logs and super vague:
Mar 31 15:42:56 aaron-Mint-Rig systemd[1]: plexmediaserver.service: Service hold-off time over, scheduling restart.
Mar 31 15:42:56 aaron-Mint-Rig systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is at 2.
-- Subject: Automatic restarting of a unit has been scheduled
-- Defined-By: systemd
-- Support: http://www.ubuntu.com/support
-- Automatic restarting of the unit plexmediaserver.service has been scheduled, as the result for
-- the configured Restart= setting for the unit.
Mar 31 15:42:56 aaron-Mint-Rig systemd[1]: Stopped Plex Media Server.
-- Subject: Unit plexmediaserver.service has finished shutting down
-- Unit plexmediaserver.service has finished shutting down.
Mar 31 15:42:56 aaron-Mint-Rig systemd[1]: Starting Plex Media Server...
-- Subject: Unit plexmediaserver.service has begun start-up
-- Unit plexmediaserver.service has begun starting up.
Mar 31 15:42:56 aaron-Mint-Rig systemd[1]: Started Plex Media Server.
-- Subject: Unit plexmediaserver.service has finished start-up
-- Unit plexmediaserver.service has finished starting up.
-- The start-up result is RESULT.
Mar 31 15:42:56 aaron-Mint-Rig systemd[1]: plexmediaserver.service: Main process exited, code=exited, status=255/n/a
Mar 31 15:42:56 aaron-Mint-Rig systemd[1]: plexmediaserver.service: Failed with result 'exit-code'.
Mar 31 15:43:01 aaron-Mint-Rig systemd[1]: Stopped Plex Media Server.
Mar 31 15:43:01 aaron-Mint-Rig systemd[1]: plexmediaserver.service: Start request repeated too quickly.
Mar 31 15:43:01 aaron-Mint-Rig systemd[1]: plexmediaserver.service: Failed with result 'exit-code'.
Mar 31 15:43:01 aaron-Mint-Rig systemd[1]: Failed to start Plex Media Server.
-- Subject: Unit plexmediaserver.service has failed
-- Unit plexmediaserver.service has failed.
-- The result is RESULT.
