Ubuntu 20.04 Plex Failed to Start
Server Version#: Likely latest
Hi Guys,
I migrated my Plex Server from a Ubuntu Server to Ubuntu.
I followed the plex migration instructions:
https://support.plex.tv/articles/201370363-move-an-install-to-another-system/
First installing and then signing out of the plex app and then stopping it.
After stopping it I copied across the library details:
/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/
Then restarted the server.
Unfortunately it now fails to start:
● plexmediaserver.service - Plex Media Server
     Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)
     Active: failed (Result: exit-code) since Thu 2021-08-19 17:39:51 BST; 13min ago
    Process: 3291 ExecStartPre=/bin/sh -c /usr/bin/test -d "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "${P>
    Process: 3293 ExecStart=/bin/sh -c  export PLEX_MEDIA_SERVER_INFO_VENDOR="$(grep ^NAME= /etc/os-release | awk -F= "{print \>
   Main PID: 3293 (code=exited, status=255/EXCEPTION)
Aug 19 17:39:51 Madmax-PLEX systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is at 3.
Aug 19 17:39:51 Madmax-PLEX systemd[1]: Stopped Plex Media Server.
Aug 19 17:39:51 Madmax-PLEX systemd[1]: plexmediaserver.service: Start request repeated too quickly.
Aug 19 17:39:51 Madmax-PLEX systemd[1]: plexmediaserver.service: Failed with result 'exit-code'.
Aug 19 17:39:51 Madmax-PLEX systemd[1]: Failed to start Plex Media Server.
Issue may be related to " For Linux/NAS systems, make sure that the directories and contents are all owned by plex:plex (or whichever user you have running Plex Media Server under)." from the migration page. Sadly I didn’t quite understand this.
Any idea how I should begin to diagnose the issue? Let me know if I need to post any logs/Ubuntu details.
Any help is much appreciated. Thanks!
Think about what you did.
  1. You copied files from somewhere else,
  2. With a different username
  3. What happens when a non-privileged user attempts to access a file it doesn’t own?
What’s the remedy? It should be obvious –
sudo chown -R plex:plex /var/lib/plexmediaserver
It’s in posts and documentation throughout the forum.
Fixed it perfectly many thanks.
Apologies, wasn’t sure what the issue could be. Cheers for clearing it up =D
