Pointers On Converting From A Strm To A Plugin
I’m quite new to Plex (sp pl. excuse the noob questions) and love the way the content is organized and am looking to get the videos from a site .
Am able to get one video at a time using the strm so I know the Site Configuration is ok . I’ve tried to use an existing plugin but none of them exist that are really basic which is what I need .
Any ideas on how I can get going ?
Am looking for the basic steps like do I create a MediaContainer or DirectoryContainer and which function ?
(Yes , have seen the wiki/docs , thread on plugin dev but its not sufficient for a noob like me — I need simple sample :slight_smile: )
The strm is :
plex://localhost/video/:/webkit?url=http://ishare.rediff.com/video/entertainment/rajesh-khanna-makes-wildcard-entry-into-bigg-boss/824012
and my xml file in the root Sites Configuration is :
<?xml version="1.0" encoding="UTF-8"?>
<site site=“http://ishare.rediff.com.*”
plugin=“http://ishare.rediff.com/images/svplayer_ad_20090824.swf
initialState=“playing”
version=“1.0”>
doh … found the plugin generator :slight_smile:
Sorry for the spam !
Did the generator give you all the examples you need or would more have helped?
Sorry to bump the thread, but I was wondering what the generator is used for and where it could be accessed.
The generator is used to create a skeleton plug-in to help you get started. It’s on our developer site here: http://dev.plexapp.com/tools/plugin_kickstart/
Thanks, I'll give that a go
No problem! Let us know if you get stuck at all :)
