Possibility of "select all"
Hello,
Can be possible to add the possibility to “select all” the média when we use filter.
Like if i use filter “genre>Comedy” i really need to can select all for change Comedy in Comédie, for the exemple.
We can “unselect all” but not the inverse, and select by click on one movie by movie it’s very long and boring.
Thank you.
Ok thank’s a lot !
I don’t see “hold the Shift key down and click the last item”
That’s very cool.
This is very similar to standard file managers on all major desktop operating systems. Try it on your computer.
Make it possible for the Plex app, also to select a few movies and delete them at once, why an app when always referring to the web! Asked this a million times already…
Aside of Otto’s guidance… there’s an existing feature suggestion asking for a “one-click” Select All option.
You can already do that in Plex Web – which is the main admin interface for your server while the “apps” are mostly players.
(also getting a bit off topic from the OP’s suggestion)
Considering both, I’ll go forward and close this thread.
