Possible DVR Deleting Non-DVR TV Episodes?
Hello everyone,
I’ve been enjoying Plex DVR but have come across an odd problem. I’m not even sure if the DVR is the cause, but repeatedly I’ve had non-DVR television episodes deleted. I’d be happy to info in addition to the details below to figure out the actual cause of the problem.
I’m using a WinTV-DualHD USB tuner, running Plex on Windows 10.
I recorded a few episodes of Kolchak: The Night Stalker on a local over-the-air station. These went to a library labeled “DVR TV Shows,” and I deleted episodes as I watched them. I watched and deleted a few episodes over the past few weeks.
I eventually decided not to wait for weekly broadcasts and get the whole series–one season, twenty episodes–on my own. I put these 20 episodes in my library labeled “TV Shows,” separate from the DVR recordings (“DVR TV Shows”).
I no longer have recordings scheduled for the show on the DVR, nor do I have recorded episodes scheduled to be deleted.
On repeated occasions, 17 of those episodes (not recorded on DVR) have ended up deleted from that TV Shows library folder. I found them in the Recycle Bin and simply restored them. I haven’t found an exact pattern for when this happens.
Each time this happens, the same 3 episodes remain in my TV Shows library.
I have had problems in the past with Plex not finding media files, but I’ve never had problems with Plex deleting files. I could be wrong in my assumption that this has anything to do with the DVR directly, of course.
This is a small quirk, and I have an easy work around (simply restore from Recycle Bin) but I assume solving this would solve problems for other people, so please let me know what information I can supply to troubleshoot this.
Thanks in advance for everyone’s time and assistance.
jimbosuave
p.s. After each recent Plex update, Plex cannot find my WinTV-DualHD USB tuner. Again I’ve had an easy work around: delete and restart. I assume this is already being worked on, so if there’s a thread that anyone has found (I haven’t) please let me know.
Check your library settings for the show. I personally set all shows to keep all episodes. Any other setting will delete episodes.
Ah!
I had set those delete settings for the recordings, but I didn’t realize that there were similar settings for the shows overall, regardless of whether they are DVR recordings.
Yes, I stopped setting for automatic deletion on all my recordings, but didn’t know how to access Kolchak: The Night Stalker settings since I no longer had recordings scheduled for it.
Problem solved! Thank you for your quick and clear response.
jimbosuave
