Posters not fetched for select movies
Server Version#:1.18.7.2457
Player Version#:4.22.2
So the problem is that for a few movies posters are not fetched. I’m trying to figure out how to fix this. I reinstalled Linux Mint from scratch and installed Plex Media Server via Snap. Created a new “TestMovies” library and set it to look in a folder with only two files and using the Plex Movie agent. I have enabled CineMaterial under the Plex Movie agent in the settings. Files are named as follows.
Fantastic Beasts: The Crimes of Grindelwald (2018).mkv
All About Us (2007).m4v
Fantastic Beasts displays correctly, but All About Us simply has a screenshot from the movie. I do notice that The Movie DB does not have a poster for All About Us. However, IMDB and CineMaterial both do. Yet nothing show up for the poster, even if I try to manually edit. It does show the IMDB rating and description.
The other item to note is that for another test, I temporarily setup a PMS on an iMac and the poster is fetched and appears correctly. I can attach logs, but what log is needed? The entire .zip file? Help would be appreciated as a clean install was my last hope.
yes, Full log zip helps because I can freely jump into and look at any of the agent logs.
Link to the .zip
https://drive.google.com/open?id=1GzmP1R2mvXhsr26xed7IHo0Q6LaEKakK
Thanks… checking and testing here
You’re using Freebase in your agent stack? (settings- server- agents)?
2020-03-15 12:59:46,856 (7ff92f7fe700) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/services/tmdb?uri=%2Fsearch%2Fmovie%3Fquery%3DAll%2BAbout%2BUs%26year%3D2007%26language%3Den%26include_adult%3Dtrue'
2020-03-15 12:59:49,161 (7ff92f7fe700) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.agents.themoviedb/messaging/function/TWVzc2FnZUtpdDpHZXRJbWRiSWQ_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMQpzNQozNTY4NHM3CnRtZGJfaWRyMAo_'
2020-03-15 12:59:53,813 (7ff92f7fe700) :  INFO (__init__:292) - MetadataSearchResult(lang='en', thumb=None, score=90, year=2007, id='tt0858424', name='All About Us')
2020-03-15 12:59:53,815 (7ff92f7fe700) :  DEBUG (runtime:88) - Sending packed state data (604 bytes)
2020-03-15 12:59:53,815 (7ff92f7fe700) :  DEBUG (runtime:924) - Response: [200] str, 640 bytes
2020-03-15 12:59:53,861 (7ff92f7fe700) :  DEBUG (runtime:717) - Handling request GET /:/plugins/com.plexapp.agents.imdb/messaging/function/X0FnZW50S2l0OlVwZGF0ZU1ldGFkYXRh/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMTAKczIKZW5zNApsYW5nYjFzNQpmb3JjZWIwczgKcGVyaW9kaWNzMQoxczQKZGJpZGkwCnM3CnZlcnNpb25uczEwCnBhcmVudEdVSURuczgKcGFyZW50SURzNQpNb3ZpZXMxMAptZWRpYV90eXBlczQzCmNvbS5wbGV4YXBwLmFnZW50cy5pbWRiOi8vdHQwODU4NDI0P2xhbmc9ZW5zNApndWlkczkKdHQwODU4NDI0czIKaWRyMAo_
2020-03-15 12:59:53,863 (7ff92f7fe700) :  DEBUG (runtime:814) - Found route matching /:/plugins/com.plexapp.agents.imdb/messaging/function/X0FnZW50S2l0OlVwZGF0ZU1ldGFkYXRh/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMTAKczIKZW5zNApsYW5nYjFzNQpmb3JjZWIwczgKcGVyaW9kaWNzMQoxczQKZGJpZGkwCnM3CnZlcnNpb25uczEwCnBhcmVudEdVSURuczgKcGFyZW50SURzNQpNb3ZpZXMxMAptZWRpYV90eXBlczQzCmNvbS5wbGV4YXBwLmFnZW50cy5pbWRiOi8vdHQwODU4NDI0P2xhbmc9ZW5zNApndWlkczkKdHQwODU4NDI0czIKaWRyMAo_
2020-03-15 12:59:53,864 (7ff92f7fe700) :  DEBUG (model:32) - Loading model with GUID com.plexapp.agents.imdb://tt0858424?lang=en
2020-03-15 12:59:53,866 (7ff92f7fe700) :  ERROR (model:205) - Cannot read model from /var/snap/plexmediaserver/common/Library/Application Support/Plex Media Server/Metadata/Movies/e/a50c5e40810ac249af7fe51114d9c3051f59585.bundle/Contents/com.plexapp.agents.imdb
2020-03-15 12:59:53,866 (7ff92f7fe700) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/library/metadata/1/tree'
2020-03-15 12:59:53,873 (7ff92f7fe700) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/services/tmdb?uri=%2Fconfiguration'
2020-03-15 12:59:53,880 (7ff92e7fc700) :  DEBUG (runtime:717) - Handling request GET /:/plugins/com.plexapp.agents.imdb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_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__
2020-03-15 12:59:53,881 (7ff92e7fc700) :  DEBUG (runtime:49) - Received packed state data (580 bytes)
2020-03-15 12:59:53,883 (7ff92e7fc700) :  DEBUG (runtime:814) - Found route matching /:/plugins/com.plexapp.agents.imdb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_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__
2020-03-15 12:59:53,883 (7ff92e7fc700) :  INFO (agentkit:957) - Searching for matches for {'openSubtitlesHash': '457bcfc6c2d6db20', 'name': 'Fantastic Beasts: The Crimes of Grindelwald', 'year': '2018', 'filename': '%2Fmedia%2Fmaeks84%2FPlexRaid%2FTestMovies%2FFantastic%20Beasts%3A%20%20The%20Crimes%20of%20Grindelwald%20%282018%29%2Emkv', 'plexHash': '6e62fec4113b9bf7bffc9a84ff828cbb18e11f42', 'duration': '-1', 'id': '2'}
2020-03-15 12:59:53,884 (7ff92e7fc700) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/library/metadata/2/tree'
2020-03-15 12:59:53,888 (7ff92e7fc700) :  INFO (__init__:138) - checking hash search vector: https://meta.plex.tv/movie/hash/6e/6e62fec4113b9bf7bffc9a84ff828cbb18e11f42.xml
2020-03-15 12:59:53,890 (7ff92e7fc700) :  DEBUG (networking:143) - Requesting 'https://meta.plex.tv/movie/hash/6e/6e62fec4113b9bf7bffc9a84ff828cbb18e11f42.xml'
2020-03-15 12:59:55,298 (7ff92e7fc700) :  ERROR (networking:196) - Error opening URL 'https://meta.plex.tv/movie/hash/6e/6e62fec4113b9bf7bffc9a84ff828cbb18e11f42.xml'
2020-03-15 12:59:55,299 (7ff92e7fc700) :  INFO (__init__:165) - freebase/proxy hash lookup failed: HTTP Error 404: Not Found
2020-03-15 12:59:55,299 (7ff92e7fc700) :  INFO (__init__:169) - Scoring {}
2020-03-15 12:59:55,300 (7ff92e7fc700) :  INFO (__init__:438) - ---- HASH RESULTS MAP ----
2020-03-15 12:59:55,300 (7ff92e7fc700) :  INFO (__init__:439) - {}
2020-03-15 12:59:55,301 (7ff92e7fc700) :  INFO (__init__:138) - checking title/year search vector: https://meta.plex.tv/movie/guid/c3/c35fe35dc4cc16383573b9e610618fac2370866c.xml
2020-03-15 12:59:55,302 (7ff92e7fc700) :  DEBUG (networking:143) - Requesting 'https://meta.plex.tv/movie/guid/c3/c35fe35dc4cc16383573b9e610618fac2370866c.xml'
2020-03-15 12:59:55,438 (7ff92e7fc700) :  INFO (__init__:169) - Scoring {'tt4123430': [5, u'Fantastic Beasts the Crimes of Grindelwald 2018', None, 98, 35950, 0]}
2020-03-15 12:59:55,439 (7ff92e7fc700) :  INFO (__init__:198) - Exception applying year penalty/bonus
2020-03-15 12:59:55,439 (7ff92e7fc700) :  INFO (__init__:464) - ---- TITLE_YEAR RESULTS MAP ----
2020-03-15 12:59:55,439 (7ff92e7fc700) :  INFO (__init__:465) - {'tt4123430': [5, u'Fantastic Beasts the Crimes of Grindelwald 2018', None, 98, 35950, 94]}
2020-03-15 12:59:55,441 (7ff92e7fc700) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/services/tmdb?uri=%2Fmovie%2Ftt4123430%3Fappend_to_response%3Dreleases%2Ccredits%26language%3D'
2020-03-15 12:59:55,999 (7ff92f7fe700) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/services/tmdb?uri=%2Fmovie%2Ftt0858424%3Fappend_to_response%3Dreleases%2Ccredits%26language%3Den'
2020-03-15 12:59:57,619 (7ff92e7fc700) :  INFO (__init__:473) - Adding title_year match: Fantastic Beasts: The Crimes of Grindelwald (2018) score=94, key=tt4123430
2020-03-15 12:59:57,619 (7ff92e7fc700) :  INFO (__init__:487) - ---- TMDb RESULTS MAP ----
2020-03-15 12:59:57,621 (7ff92e7fc700) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/services/tmdb?uri=%2Fsearch%2Fmovie%3Fquery%3DFantastic%2BBeasts%253A%2BThe%2BCrimes%2Bof%2BGrindelwald%26year%3D2018%26language%3Den%26include_adult%3Dtrue'
2020-03-15 12:59:58,244 (7ff92f7fe700) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/services/tmdb?uri=%2Fmovie%2Ftt0858424%2Fimages'
2020-03-15 12:59:59,859 (7ff92e7fc700) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.agents.themoviedb/messaging/function/TWVzc2FnZUtpdDpHZXRJbWRiSWQ_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMQpzNgozMzg5NTJzNwp0bWRiX2lkcjAK'
2020-03-15 13:00:00,498 (7ff92f7fe700) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/services/tmdb?uri=%2Fmovie%2F35684%2Frecommendations'
2020-03-15 13:00:02,033 (7ff92e7fc700) :  INFO (__init__:292) - MetadataSearchResult(lang='en', thumb=None, score=90, year=2018, id='tt4123430', name='Fantastic Beasts: The Crimes of Grindelwald')
2020-03-15 13:00:02,036 (7ff92e7fc700) :  DEBUG (runtime:88) - Sending packed state data (604 bytes)
2020-03-15 13:00:02,036 (7ff92e7fc700) :  DEBUG (runtime:924) - Response: [200] str, 680 bytes
2020-03-15 13:00:02,068 (7ff92e7fc700) :  DEBUG (runtime:717) - Handling request GET /:/plugins/com.plexapp.agents.imdb/messaging/function/X0FnZW50S2l0OlVwZGF0ZU1ldGFkYXRh/Y2VyZWFsMQoxCmxpc3QKMApyMAo_
Not sure yet but looks like a problem with bringing securing the match at 94% which should be more than enough.
I have seen it mentioned that Freebase was something that is now dead. I haven’t added it in anyway that I know of.
I see you have Local Media Assets on top. This is ill advised.
Place it at the bottom. Being at the bottom allows it to pick up the extras which other agents don’t get. At the top will preempt proper matching.
LMA is a supplemental agent. It’s not a primary agent.
I don’t think I changed it from the default, but I could have. I moved LMA to the bottom and refreshed metadata. No change. :frowning_face:
It’s not that easy.
The media is already mis-matched.
You essentially have to tear it down and start again.
The ability to unmatch & rematch doesn’t exist
Do you mean the Plex Dance? I was in that process when you replied and it too resulted in no change. Do you mean something more?
As a test. . do it this way.
  1. Create a new “Test Movie” section.
  2. There are specific changes when making this under Advanced and while creating it. (we are going to create a pure , clean, isolated section)
    a. Don’t use anything from other sections
    b. turn off collections
    c. Turn off thumbnails.
  3. Add your smallest directory tree to it (smallest group)
  4. Now launch that to build. Don’t disturb it with other activities while it’s building. This will serve as our “control”.
I made a new directory with three properly matching movies. Should I put a copy of All About Us in it before adding the library to plex?
edit: Went with 2a and left All About Us out of the directory. The three movies show as expected.
So the fresh match did exactly as expected. It is a new media item and matched using the now-current agent settings.
Keep testing.
I think you’ll see where this has to go
If you mean to now add “All About Us”, just did and it has the same behavior as before. No poster.
That’s what I feared. It’s not you or me. It’s upstream somewhere/somehow.
I get the same results.
I’m making direct calls to it now to see if I can find where they are broken
Well that makes me feel better in some ways anyway. Hopefully you can figure something out. Just FYI, I was in the process of trying another machine and it also has the same behavior. Also, the local media assets are first by default in the Plex Movie Agent.
I did just get “Fantastic Beasts: The Crimes of Grindelwald” to match up cleanly.
Screenshot from 2020-03-15 19-03-05
Just wondering if your calls resulted in anything? Fantastic Beasts: The Crimes of Grindelwald was never giving any trouble on my end.
Just to followup, I was never able to get the posters to fetch using Plex. However, I bypassed the issue by installing Tiny Media Manager. Used that to download and store the posters locally. Bonus - now my files are easier to name!
