Plex doesn't load Movie Poster
Server Version#: 1.18.9.2571
Player Version#: -
The most movies get the correct meta data and movie posters. But sometimes I need to make the assignment of a movie by hand. Thats not very hard. But I have a problem with two movies:
  • Joker
  • Birds Of Prey: The Emancipation Of Harley Quinn
Plex fetches the right meta information (description and so on) from ‘the movies database’.
But the movie poster doesn’t appear. But the source has these poster information.
The downloading of the meta data needs a lot of time.
Does somebody has an idea?
Mine was doing this as well. Use the FIX MATCH option…You may get more than one HIT. Mine was doing it as I had my FILENAME wrong. Some of them are CASE SENSITIVE (for example I had ‘12 Years A Slave (2013)’ - and it Failed every time… changed to the way it was listed on IMDB ‘12 Years a Slave (2013)’ and BINGO - worked.)
bh
I already used that function. And yes I find the entry for the movie. So plex catchs meta information like the title and the description. But it doesn’t catch the poster/image…
What if you use the EDIT PENCIL, can you choose another POSTER? Some of my movies have * or more in there to choose from.
bh
I can choose a other one. Then the poster become grey:
After hit the refresh meta data button I get the wrong picture again.
Here some log information:
Mar 27, 2020 19:51:52.583 [0x7fcf7a01a700] INFO - Plex Media Scanner v1.18.9.2571-e106a8a91 - Docker Docker Container x86_64 - build: linux-x86_64 - GMT 01:00
Mar 27, 2020 19:51:52.583 [0x7fcf7a01a700] INFO - Linux version: 4.9.0-9-amd64, language: C
Mar 27, 2020 19:51:52.583 [0x7fcf7a01a700] INFO - Processor Intel(R) Xeon(R) CPU E3-1225 v5 @ 3.30GHz
Mar 27, 2020 19:51:52.583 [0x7fcf7a01a700] INFO - /usr/lib/plexmediaserver/Plex Media Scanner --analyze --item 5074 --log-file-suffix  Analysis
Mar 27, 2020 19:51:52.585 [0x7fcf8272b740] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.26.0, threadsafe=1
Mar 27, 2020 19:51:52.646 [0x7fcf8272b740] DEBUG - Analyzing media parts for item 5074 (Birds Of Prey: The Emancipation Of Harley Quinn): 5021
Mar 27, 2020 19:51:52.646 [0x7fcf8272b740] DEBUG - [ID 5147] Media part analysis: /data/Filme/Birds of Prey - The Emancipation of Harley Quinn/movie.mkv
Mar 27, 2020 19:51:52.646 [0x7fcf8272b740] DEBUG - [MI] Opening input file: "/data/Filme/Birds of Prey - The Emancipation of Harley Quinn/movie.mkv"
Mar 27, 2020 19:51:52.647 [0x7fcf8272b740] DEBUG - [FFMPEG] - Opening '/data/Filme/Birds of Prey - The Emancipation of Harley Quinn/movie.mkv' for reading
Mar 27, 2020 19:51:52.647 [0x7fcf8272b740] DEBUG - [FFMPEG] - Setting default whitelist 'file,crypto'
Mar 27, 2020 19:51:52.672 [0x7fcf8272b740] DEBUG - [FFMPEG] - Format matroska,webm probed with size=2048 and score=100
Mar 27, 2020 19:51:52.685 [0x7fcf8272b740] DEBUG - [FFMPEG] - st:0 removing common factor 1000000 from timebase
Mar 27, 2020 19:51:52.685 [0x7fcf8272b740] DEBUG - [FFMPEG] - st:1 removing common factor 1000000 from timebase
Mar 27, 2020 19:51:52.685 [0x7fcf8272b740] DEBUG - [FFMPEG] - st:2 removing common factor 1000000 from timebase
Mar 27, 2020 19:51:52.685 [0x7fcf8272b740] DEBUG - [FFMPEG] - Before avformat_find_stream_info() pos: 6291 bytes read:33925 seeks:2 nb_streams:3
Mar 27, 2020 19:51:52.685 [0x7fcf8272b740] DEBUG - [FFMPEG] - nal_unit_type: 7(SPS), nal_ref_idc: 1
Mar 27, 2020 19:51:52.685 [0x7fcf8272b740] DEBUG - [FFMPEG] - nal_unit_type: 8(PPS), nal_ref_idc: 1
Mar 27, 2020 19:51:52.686 [0x7fcf8272b740] DEBUG - [FFMPEG] - nal_unit_type: 7(SPS), nal_ref_idc: 1
Mar 27, 2020 19:51:52.686 [0x7fcf8272b740] DEBUG - [FFMPEG] - nal_unit_type: 8(PPS), nal_ref_idc: 1
Mar 27, 2020 19:51:52.686 [0x7fcf8272b740] DEBUG - [FFMPEG] - nal_unit_type: 6(SEI), nal_ref_idc: 0
Mar 27, 2020 19:51:52.686 [0x7fcf8272b740] DEBUG - [FFMPEG] - nal_unit_type: 5(IDR), nal_ref_idc: 1
Mar 27, 2020 19:51:52.686 [0x7fcf8272b740] DEBUG - [FFMPEG] - Format yuv420p chosen by get_format().
Mar 27, 2020 19:51:52.690 [0x7fcf8272b740] DEBUG - [FFMPEG] - nal_unit_type: 6(SEI), nal_ref_idc: 0
Mar 27, 2020 19:51:52.690 [0x7fcf8272b740] DEBUG - [FFMPEG] - nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1
Mar 27, 2020 19:51:52.691 [0x7fcf8272b740] DEBUG - [FFMPEG] - no picture
Mar 27, 2020 19:51:52.692 [0x7fcf8272b740] DEBUG - [FFMPEG] - nal_unit_type: 6(SEI), nal_ref_idc: 0
Mar 27, 2020 19:51:52.692 [0x7fcf8272b740] DEBUG - [FFMPEG] - nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 0
Mar 27, 2020 19:51:52.696 [0x7fcf8272b740] DEBUG - [FFMPEG] - nal_unit_type: 6(SEI), nal_ref_idc: 0
Mar 27, 2020 19:51:52.696 [0x7fcf8272b740] DEBUG - [FFMPEG] - nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1
Mar 27, 2020 19:51:52.699 [0x7fcf8272b740] DEBUG - [FFMPEG] - nal_unit_type: 6(SEI), nal_ref_idc: 0
Mar 27, 2020 19:51:52.699 [0x7fcf8272b740] DEBUG - [FFMPEG] - nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 0
Mar 27, 2020 19:51:52.701 [0x7fcf8272b740] DEBUG - [FFMPEG] - nal_unit_type: 6(SEI), nal_ref_idc: 0
Mar 27, 2020 19:51:52.701 [0x7fcf8272b740] DEBUG - [FFMPEG] - nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1
Mar 27, 2020 19:51:52.704 [0x7fcf8272b740] DEBUG - [FFMPEG] - nal_unit_type: 6(SEI), nal_ref_idc: 0
Mar 27, 2020 19:51:52.704 [0x7fcf8272b740] DEBUG - [FFMPEG] - nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 0
Mar 27, 2020 19:51:52.706 [0x7fcf8272b740] DEBUG - [FFMPEG] - nal_unit_type: 6(SEI), nal_ref_idc: 0
Mar 27, 2020 19:51:52.706 [0x7fcf8272b740] DEBUG - [FFMPEG] - nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1
Mar 27, 2020 19:51:52.709 [0x7fcf8272b740] DEBUG - [FFMPEG] - first_dts 292 not matching first dts NOPTS (pts 0, duration 41) in the queue
Mar 27, 2020 19:51:52.710 [0x7fcf8272b740] DEBUG - [FFMPEG] - All info found
Mar 27, 2020 19:51:52.710 [0x7fcf8272b740] DEBUG - [FFMPEG] - After avformat_find_stream_info() pos: 383198 bytes read:438080 seeks:2 frames:118
Mar 27, 2020 19:51:52.710 [0x7fcf8272b740] DEBUG - [MI]  * fe769bef4661df4f8620efb79983f6a12a0109e2 [mkv h264/ac3] Duration: 6532736ms, 1920x802 (2.394015) 23.976fps, bitrate=5130kbps, audio channels=6, optimizedForStreaming=0 ("/data/Filme/Birds of Prey - The Emancipation of Harley Quinn/movie.mkv")
Mar 27, 2020 19:51:52.710 [0x7fcf8272b740] DEBUG - [MI] Importing 13 media chapters.
Mar 27, 2020 19:51:52.710 [0x7fcf8272b740] DEBUG - [MI] Chapters had generic titles, clearing.
Mar 27, 2020 19:51:52.711 [0x7fcf8272b740] DEBUG - [MI] Closing input file: "/data/Filme/Birds of Prey - The Emancipation of Harley Quinn/movie.mkv"
Mar 27, 2020 19:51:52.713 [0x7fcf8272b740] DEBUG - Updating media item 5021, size=4189537498, metadata_item_id=5074
Mar 27, 2020 19:51:52.713 [0x7fcf8272b740] DEBUG - Updating part with ID=5147 [/data/Filme/Birds of Prey - The Emancipation of Harley Quinn/movie.mkv]
Mar 27, 2020 19:51:52.713 [0x7fcf7303c700] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=11&metadataItemID=5074&metadataType=1&state=-1&mediaState=analyzing
Mar 27, 2020 19:51:52.714 [0x7fcf7303c700] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=11&metadataItemID=5074&metadataType=1&state=-1&mediaState=analyzing
Mar 27, 2020 19:51:52.714 [0x7fcf7303c700] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=11&metadataItemID=5074&metadataType=1&state=-1&mediaState=thumbnailing
Mar 27, 2020 19:51:52.715 [0x7fcf7303c700] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=11&metadataItemID=5074&metadataType=1&state=-1&mediaState=thumbnailing
Mar 27, 2020 19:51:52.715 [0x7fcf7303c700] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=11&metadataItemID=5074&metadataType=1&state=-1&mediaState=idle
Mar 27, 2020 19:51:52.715 [0x7fcf7303c700] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=11&metadataItemID=5074&metadataType=1&state=-1&mediaState=idle
Mar 27, 2020 19:51:52.718 [0x7fcf8272b740] DEBUG - Doing expensive tags write for 'Birds Of Prey: The Emancipation Of Harley Quinn' because something changed.
This is happening to myself and most of my friends. Something somewhere broke in the last 48 hours. I’ve been having this problem with new library entries since yesterday. Metadata comes through 50% of the time, but no posters.
Im not sure if this is new. I has these movies longer on my server
Just restart your server (by exiting whatever you host it on) then rescan all metadata
Restarting server and re-scanning did not work in my case. Even rebooted PC and no dice
Don’t rescan… that won’t work. Instead, click the 3 dots, manage library, refresh all metadata. That will scan everything and should work.
Please let me know how it goes, that’s how I fixed mine. Also, just make sure you are running the neatest version, just in case.
Also also, this issue was fixed. I read it in another thread as there were several people having the same issue.
No that don’t work
German user with cable and a Fritzbox?
I’m so sorry. That worked for me perfectly. I am lost now with no other answer. Sorry.
@Coxeroni yes i am
Then I have a thread for you:
It is an issue with that specific combination.
Having the same problem. I can verify that this is an issue with the Linux server specifically, since my Windows one downloads all movie posters with no problem. The Linux one, however, does not download all the poster art. (Most do, but around 10% don’t.) Yes, even for movies that are properly matched. Yes, even after refreshing the metadata. Yes, even after the most recent Plex update.
Obviously, I can track down each individual movie online and upload them one by one. But there are perhaps a hundred movies I’d have to do that for. And if Windows Plex works on its own, why doesn’t Linux?
For some reason my Plex Server does not load any movie posters whatsoever.
TV Shows are perfect and so is Music but no matter what, It just will not load one movie poster or thumnail for films. All I see are random snapshots from the movie in question.
Followed the instructions about directories and naming convention, all to no avail.
It smells of a bug somehow.
Setup: Ubuntu 19.10 out of the box. Latest PlexPass version.
Anyone else seeing this?
Same here, already created a differnet post about this. Matches but won’t dowload the posters, and if manually chose, won’t update. I sent my logs. Server Version 1.19.1.2645 QNAP and Fritzbox Cable.
For all users with fritzbox cable Coxeroni gave already a solution…
Fritzbox Cable, login to your Fritzbox, in the land hand menu bottom choose something like “topics” (Inhalt), navigate to "FRITZ!Box Support“ and look for some “Package Hardware Acceleration” Settings. Disable it. The issue has already been reported to AVM (Fritzbox)
