Posters Reset
Server Version#: 1.42.2.10156
Just had dozens of my posters blank out on me in my movie library… went to screen captures instead of any of the available posters. When I refreshed metadata to see if that’d get posters back, they came back with completely different posters, not the ones I had selected previously despite still being available in the poster selection screen. These were clearly new provider ones because many had copy and cast info all over them now.
All I was doing was updating some new rips and bam… posters missing artwork.
TV shows seem unaffected.
I thought Plex had sorted out this issue of messing with people’s posters. In fact my posters were rarely ever changed - only if DMCA kicked in - because I knew the “pick one” trick to lock them and did that, but that didn’t save me this time.
Example movies are Usual Suspects, Cutthroat Island, Bad Boys, Zootopia and Sneakers just to name a few. I know for a fact these are titles I manually selected at one point or another.
It was promised if we manually selected posters they would stick (and any I added myself did stick) but this was really annoying. I haven’t gone through to check background artwork yet (that’ll be easier to do via the Plex Dash app). Maybe now y’all can provide a lock artwork option as has been requested over and over again?
Edit: Plex will likely go with “do it yourself” as has been the refrain from reps these days about artwork issues. I got Plex so I wouldn’t have to do it myself.
I’ve attached my logs but since this seems like it was a service side and not a server level change (no update on my server for quite some time) it probably won’t show much.
Plex Media Server Logs_2025-10-06_18-27-47.zip (5.2 MB)
Edit2: Just a week ago I went through a file cleanup auditing titles and ran DBRepair with cleanups and restarts all without any trouble the following several days.
Would appreciate confirmation that this is a Plex thing that’ll continue to happen as they update and push out their posters from their licensed artwork provider or if it’s a local server DB issue I need to do something about.
Are you still having concerns with this?
Besides locking posters, are you using
Agent = Plex Movie
Scanner = Plex Movie
Use local assets
Show us the exact folder & file naming structure for Zootopia if it’s having problems please.
If you don’t follow the Plex naming conventions, that could be a reason even if it used to work.
For example, I might have
Media/
  Movies/
    Zootopia (2016)/
      Zootopia (2016) - 1080p.AC3.mkv
Those settings and naming are all right and have been for quite some time. I’ve rarely had artwork issues even when others had reported service issues.
It very much feels like the time Plex initially pushed out their new licensed art provider artwork and it got a bit bobbled. Since that time I manually select artwork on all titles as that was the direction from reps/employees as the way to lock the art and prevent that same licensed art push “feature” from changing artwork in the future.
If it was just a server side flake out on several random titles, when it refreshed, it should have picked up the same art referenced in the DB since those manually selected posters were still available. Instead it went with their licensed art provider posters (you can tell either by the poster style - cast listings and marketing copy are typical - or which position it’s at in the picker). So what caused my DB references not to work or did something in the licensed artwork refresh override a “locked” poster?
It feels like the latter.
Additionally, I ran DBrepair just a week or so prior and it was all good and ran it after and got no errors. Artwork hasn’t flaked again on me even after multiple refreshes.
Plus, looking at the art picker you can see Plex is starting to incorporate their new square art options for mobile New Experience posters so I wouldn’t be surprised if they flaked something here again.
They broke background TV artwork several months ago and haven’t fixed it yet either (they acknowledged it right away but haven’t fixed the regression).
Having DMCA take downs remove all artwork (posters and backgrounds) and not just the offending piece with the solution “use your own artwork” is another artwork service reduction.
I’d just like them to finally follow through on providing a real “lock” for artwork that doesn’t involve managing my own local artwork files.
I appreciate the check in to try and help, but I’m just gonna chalk this one up to yet another sign Plex is now less reliable for local media services. It’s frustrating but not really a disaster.
Did it again this weekend. Bunch of posters and backgrounds got reset.
I can always tell because the posters get set to those crappy licensed ones with extra copy (actor’s names, credit info, tag lines, etc) including ones I “fixed” the last time this happened. Which already included ones I manually selected and according to Plex employees and reps will “be locked” and “won’t change” if that step is performed.
So the employee and reps that say posters reseting are user error and dismiss claims that Plex is causing this to happen (likely to meet obligations with license holders for some reason) need to stop saying that, admit Plex will change your local posters unless you provide your own artwork manually, and provide an actual lock feature (and then it might not work because TV backgrounds are still broken even if you use your own local artwork).
Can you check out some of your titles XML and confirm that they in fact have their posters locked (thumb)? Do you have posters locally stored next to the related media?
Can you describe this process a bit more? Also can you share your Server’s Library settings?
I’m gonna try to be detailed… I’m not slamming a wall of text here as a rant or anything just trying to provide as much info\context as I can in a situation where I don’t know what really will help or be the “ah ha” piece of data.
I only have a couple locally stored posters - like 2… they are personal videos I made personal artwork for and keep in the movies library (unmatched). One aspect of Plex I appreciated was not having to manage local artwork so I leveraged that a lot. Which is why the suggestions I’ve received in other threads from reps that I should manage my own local artwork is more than a little disappointing and frustrating (not that you’re doing that here - other reps in other threads).
I have several posters that I uploaded manually through the GUI - those have never changed.
Almost all my posters should be “locked” for the most part for three reasons:
  1. Plex switched from unwatched to watched flags and it covered titles on my posters. I was not a fan of the watched flags (no need to rehash). So I switched a lot of posters to put the title at the bottom - specifically ones that came to mind were Usual Suspects and Sneakers because I very specifically remember doing that with those. Then when the option to turn off watch\unwatch flags entirely came along (a suggestion I put out there at the time and was glad to get) I flipped them back to having titles on top because I preferred posters to look like the cover boxes I was used to from my video store days…. this is why I remember so many posters and notice when they change… they are cover boxes I’m used to seeing for years (just without the actor names or credits or taglines).
  2. Plex switched to gracenote and a few of my posters - but not many really - switched to ones I considered pretty bad posters at that time. In the hubbub from all the folks impacted by that it was confirmed switching artwork manually locks it so any that changed must not have been locked. I even mentioned how I barely had any changed because of doing that process myself for so many years as proof it should work. The ones that had changed at the time were only a couple and I might not have manually selected those.
  3. Unless you wanted the TMDB most voted poster to dynamically change your poster you needed to manually select a poster. I’ve been doing that for years to keep that from happening as well. It’s just part of my process when adding new titles to manually flip artwork (and I usually don’t prefer the default background art).
The time I reported it initially here I had more posters change to those licensed ones than they did when Plex originally switched to the licensed artwork provider. This time it changed ones I knew for a fact should have been locked. It was more than 20. And then others changed a few weeks later; about a dozen this time.
The first time they blanked out on me before going with the licensed artwork instead of my manually selected artwork when I ran a metadata refresh. The second time they didn’t blank out first so I didn’t run a refresh. Though I might’ve just caught it between refreshes the first time.
Zootopia, my example above, shows locked (thumb). So does Sneakers and Usual Suspects. I checked a bunch and they all show thumb listings.
One that changed the second time was Leon the Professional … I know it was manually selected and shoulda been locked because I have an international cut and I manually picked an international poster and flipped it more than once over the years because I decided to go against my “familiar cover box” and used the “Leon” title instead of the “Professional” title at one point. It shows locked now as well (thumb listings).
So either manually selecting posters isn’t actually locking them or the lock status is being ignored or missed when Plex does something with refreshing media from the licensed artwork provider. The first time coulda been a local bug but it happened again so I don’t think it is. I don’t know if there’s a way for me to check if Plex ignored the lock status or if there was a different bug that kept the lock status from being set now that I’ve “fixed” all the ones that got changed since then. In looking at a bunch of them I’ve mentioned, they all show thumb listings for posters.
The posters that were impacted in the second round of bulk changes were not the same ones as impacted in the first round. They all were spread across the alphabet in each case.
As far as what I was doing with updating new rips I was adding 1080p and 4k versions to existing titles that only had lower res versions and removing lower res versions I didn’t really need to keep anymore. Then when I went back into my library view I saw a bunch of blank posters and a refresh of the metadata pulled the licensed art instead of the originally set art. So it was possible that something got thrown off in the DB for it to pull licensed art instead of the referenced artwork I had locked. In the past I’ve had that happen… plex lose posters from some hangup or another, but a metadata refresh always brought it back to my usual posters and I hadn’t had that happen in a long time. That’s why the refresh not working this time threw me off - and was so frustrating.
I ran DBrepair since - partially because I made a lot of changes and those posters flaked out the first time and again as ChuckPa has updated the scripts and I tried them out. No problems.
My movie library is built with letter folders, not individual title folders - so bulk titles in a single folder like A-C or L-N. That means when I update a title it can trigger a scan for the titles in that folder which is likely why I might trigger a mass poster change in this process while others might not if it was a scan that triggered it and why I thought maybe it was a hiccup on my side somewhere while I was doing a lot of bulk changes.
But the second time it happened I wasn’t doing anything much at all. I don’t think I even added or changed files in the movie library for days when I noticed the batch of new “wrong” posters.
I’m not adding new titles to my library every week but pretty regularly and artwork hadn’t been randomly changing in bulk over the years until these two recent events - at least not since Plex switched to gracenote and did a “push” at that time but that push only changed a few posters for me. This was a lot more this time.
It feels like Plex updated\refreshed their licensed artwork on their side and something didn’t work right. You can tell it’s from the licensed artwork provider because of its style and its position in the art picker gui. So yeah, it feels like Plex did a push. I was hoping by naming some titles someone could see if those titles were specifically included in some regular artwork update from the license provider.
I also know Plex is working on changing the art picker right now in beta so I wouldn’t be surprised if something with that beta release testing and fiddling with the art provider setup might’ve done something.
Which library settings would you like to know specifically? It’s mostly standard recommended settings for the library itself really and for server settings I’ve enabled scan automatically, run partial scan when changes detected, Scan my Library periodically (Daily), and empty trash. Again I will mention I’ve had no artwork issues for years while adding\removing titles, versions and editions pretty regularly.
I’ve fixed the errant posters for now - fixing background art is more onerous and less of a priority so I’ll fix via PlexDash as I come across them. Let me know if there’s additional information you would like me to provide or clarify.
This is what I was after. What is your setup like? Where is your media store, local to the host or on a network share?
How was this :backhand_index_pointing_up: done? Was the original media deleted then the new rips were added? Each file existed in the same folder for a time then you removed the original file?
I run Plex on a QNAP and my files are stored there as well. I have one movie library. The titles are stored in share/media/movies/ with subfolders labeled 1-C, D-F, G-J, etc added to the library and titles are loose in those folders. Been doing it that way forever (actually started with one bulk folder but broke it out a bit several years ago to reduce scanning overhead).
Essentially, yeah. I had Angus as a 720p movie already in the 1-C folder. I add a 1080p version and made sure it matched up with the existing Plex listing as additional version and then I’d remove the 720p version (usually via Plex GUI as I was already looking at it there to verify it). Whenever I update or add versions of titles I always make sure they match up so I don’t lose watch history and such. I usually do that in ones or twos over time but at this time I did several while also doing some other cleanup.
The other cleanup was removing a lot of those duplicate versions. Initially, any titles I had in 4K I have been keeping a 720/1080 version with it as well. This has been working well for several years - Plex automatically picks the lower res version for non-4K TVs. That’s less of a need these days so I removed all those duplicate versions. I did that from the file system directly.
I did that over the course of a day or two when I noticed the posters blanked to screenshots that first time.
Sneakers, as an example, wasn’t one of the ones I added versions. I’m not positive it is all of them, but at least the majority of posters that changed weren’t ones I updated with new versions. They were likely ones I removed duplicate versions, but I removed hundreds of duplicate versions in that cleanup so the removal of a duplicate isn’t the specific trigger per title otherwise all the ones I removed woulda changed and that definitely didn’t happen.
Plus I wasn’t doing anything much - maybe added two new titles in the weeks between - when I noticed the second round of bulk poster changes.
I realize there might not be a way to track this down specifically. The only way would be to know a title’s status and detail before and after changing and that’s just not available. So if the best we can do for now is get details for tracking/reference that’s fair. Particularly without any other user corroboration.
I appreciate your attention on this and the PlexAmp server crashes topic as well. :victory_hand:
So in these folders that are holding loose files, how is versioning handled? Can you provide an example of a versioned title?
This seems a bit different than what was reported here Stop. Changing. My. Posters - #206 by dokuro. I was able to confirm the issue reported there and it seems to stim from the Server Library settings: scan automatically, run partial scan when changes detected. The simple takeaway IIRC is that PMS was scanning in the change and generating a new ratingKey, which basically treats this as a new entry. Because it’s “new” none of the locked metadata would apply.
For the titles that were affected, could you look in their XML again and compare their ratingKey to maybe a title that was recently added and one that was added around the same time. If we can determine that the ratingKey DID change then it would fit into the same issue as the linked thread. If not… well… I’ll see if I can setup a similar environment and attempt to reproduce.
I would like to suggest that you disable the partial scan setting and see if how much impact that causes to your normal day-to-day flow.
I actually think I might look at disabling some of the automatic scanning\refreshing so that’s not a bad idea. It’s convenient and has been working reliably for years but not a huge deal to just manually hit “scan now” after making changes. I’ll give it a try.
When I was fiddling with Emby I liked that they had the option to disable metadata updates on TV show library except for new episodes that were missing information and to only check for that for X number of days; useful for recently aired episodes that still need to pick up titles\art\summaries. I could disable updating on Movie library entirely or set it only to pull for missing data.
But I can’t set different metadata refresh rules for different libraries… it’s all or nothing. So if I want new TV episodes to get titles\artwork I need to leave the refresh metadata tasks enabled across all libraries right?
This is an area I think it’d be nice to have more controls and maybe per library rather than all or nothing - unless I’m missing some functions (entirely possible). Just a thought. :slightly_smiling_face:
At the time - I’ve since gotten rid of multiple versions which is what I was doing when this happened and may have been coincidence or may have been a trigger - how it worked was the file names were typically similar but with resolution info was different: title.(year).resolution.some.extra.info.mkv. So a typical example could be:
Sneakers.1992.2160p.BluRay.DTS-MA.AC3.MKV and
Sneakers.1992.1080p.BluRay.AC3.MP4 as the two versions.
Not always so exact… sometimes might be Sneakers(1992).1080p and Sneakers.1992.4k but essentially it followed title and year then variation of resolution, source and codec info. Some filenames were less similar but they all pretty much matched well because Plex has been so good at it over the years; I haven’t had to fix a bad match in ages as long as title and year were in there.
Editions, when there are more than one, are exact same filenames except with the {edition-Extended Cut} or whatever added to it.
Ah. Interesting… okay so the rating key should match up with what’s in the thumb listing (if I’m reading that other thread correctly). These keys are incremental so if an older listing has a newer ratings key - closer to a newly added title compared to a title added around the same time that might indicate that these titles are being treated as “new” when they aren’t new. Do I have that right?
If so… then here’s what I found with a caveat.
Sneakers key: 22385 (added 4 years ago)- poster changed in first round
Smokey and the Bandit key: 22384 (added same day as Sneakers) - no change
So I Married Axe Murderer key: 22418 (added a few days after Sneakers) - no change (no additional version)
Usual Suspects: 19574 (added a few months before Sneakers) - poster changed in first round
Ghostbusters key: 18435 (added several months before Sneakers) - poster changed (not sure if 1st or 2nd round - was behind a collection poster and I didn’t check those the first time)
Leon the Professional: 18965 - poster changed in 2nd round
Cutthroat Island: 52655 (added in 8/2023) - poster changed in first round
Street Fighter: 54921 (added in 12/2023) - poster changed first round (no additional version)
Desperado: 57922 (added in 8/2024) - poster changed in 2nd round
A-Team key: 70797 (added last week) - no change (no additional version)
Addams Family: 69968 (added in Aug) - no change (no additional version)
Rescuers Down Under: 70415 (added 9/2025 - no additional version) - poster changed in 2nd round of changes
The caveat - it’s hard for me to compare when title was added vs file added dates because I added SD\HD versions before the 4kUHD versions and I deleted those SD\HD versions for titles with 4k but I tried to grab decent representative ones either way. Based on that it doesn’t look like any titles were having keys reset or change like in that other thread.
Hope that helps and let me know if anything is unclear.
Yeah, that’s my theory. I haven’t dug into your full post yet but just wanted to confirm this first. Need to step away for bit but will return and look for through this with fresh eyes. Thanks for your patience and willingness to troubleshoot, even if it’s on a hunch. :plexheart:
