Server Version#: 1.25.0.5282
Player Version#: Version 4.71.0
Newest public version DVR, post processing script now generates an error and recording is lost.
Worked fine on the older version, the only change was upgraded to the newest public version.
Right after the recording ends In the DVR guide it shows “Cannot record airing in the past” but I have noticed sometimes it changes to “could not move recorded media to the destination”
Anyone else with the same problem?
for now I have removed the post processing script however I would like to add it back. Converts from Mpeg 2 to mp4
The script has not changed and works fine if manually run from the command line via SSH.
no one have any idea’s? I had to roll back to the prior version and everything is working as expected so this does appear to be related to the newer version.
Still the same problem in the newest version. Anyone have any idea’s? Adding some snippet from the log where it reported it cannot move the file after post processing, but I don’t think the post processing is running as it seems to only take a second.
Trying to narrow it down, I see the following in the newest version of the server.
Dec 07, 2021 10:16:01.555 [0x7f00e9cfdb38] DEBUG - [Grabber/284f6b3ccf3c79aface983ab342c7f7fb6cc2974/JobRunner] Job running: ‘/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Scripts/DVRPostprocessing.sh’ ‘/volume1/Media/TV Shows/.grab/284f6b3ccf3c79aface983ab342c7f7fb6cc2974-3138b935433ea56926f9564ac68f9b67c0a6e1ad/Tik Tak (2019) - S01E25 - Tik Tak.ts’
Dec 07, 2021 10:16:03.574 [0x7f00ee2a3b38] DEBUG - Jobs: ‘/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Scripts/DVRPostprocessing.sh’ exit code for process 9518 is 0 (success)
Dec 07, 2021 10:16:03.574 [0x7f00e9cfdb38] ERROR - [Grabber/284f6b3ccf3c79aface983ab342c7f7fb6cc2974] Recorder: Postprocessing script ‘/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Scripts/DVRPostprocessing.sh’ seems to have deleted the file. Silly script.
In the older version it successfully runs
Dec 07, 2021 10:37:00.446 [0x7f79c78a3b38] DEBUG - [Grabber/996b17fccfc385baf6ebd7df113f1ac8b7efbf81/JobRunner] Job running: ‘/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Scripts/DVRPostprocessing.sh’ ‘/volume1/Media/TV Shows/.grab/996b17fccfc385baf6ebd7df113f1ac8b7efbf81-3138b935433ea56926f9564ac68f9b67c0a6e1ad/Cutie Pugs (2018) - S01E22 - Dance Party.ts’
Dec 07, 2021 10:38:20.356 [0x7f79c8e8ab38] DEBUG - Jobs: ‘/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Scripts/DVRPostprocessing.sh’ exit code for process 19007 is 0 (success)
Dec 07, 2021 10:38:20.356 [0x7f79c78a3b38] DEBUG - [Grabber/996b17fccfc385baf6ebd7df113f1ac8b7efbf81] Recorder: Postprocessing script ‘/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Scripts/DVRPostprocessing.sh’ was successful in 79.9 seconds. Nicely done.
The script hasn’t changed all all the only change is the version of PMS upgraded from Version 1.24.5.5173 to 1.25.1.5286
