Power failure - plex gives a 404 not found
Server Version: 1.21.1.3842
Had a power failure earlier, pc was bluescreening when it came back, I got in to safe mode ok, then rebooted it again at it is fine now except for plex. subsequent reboots yield the same behavior, any suggestions?
server log:
Jan 07, 2021 23:26:39.528 [15612] DEBUG - Connection Tester: The server Spicy Server is a valid media provider.
Jan 07, 2021 23:26:39.529 [15612] DEBUG - HTTP requesting GET https://142-126-142-123.2846010c6226409a90dcda9464ef209f.plex.direct:32400/security/token?type=delegation&scope=all&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Jan 07, 2021 23:26:39.613 [11368] DEBUG - EventSource: Connected in 140 ms.
Jan 07, 2021 23:26:39.613 [11824] DEBUG - EventSource: Wrote data, reading reply.
Jan 07, 2021 23:26:39.814 [11824] DEBUG - EventSource: Read HTTP reply header.
Jan 07, 2021 23:26:39.814 [11824] DEBUG - EventSource: Successfully connected to 142-126-142-123.2846010c6226409a90dcda9464ef209f.plex.direct.
Jan 07, 2021 23:26:40.026 [15612] DEBUG - HTTP 200 response from GET https://142-126-142-123.2846010c6226409a90dcda9464ef209f.plex.direct:32400/security/token?type=delegation&scope=all&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Jan 07, 2021 23:26:40.026 [0644] DEBUG - Media Server: Tested all servers in 1.2 seconds.
Jan 07, 2021 23:26:40.325 [1128] DEBUG - HTTP 200 response from POST http://127.0.0.1:32600/devices/discover
Jan 07, 2021 23:26:40.326 [2080] DEBUG - NAT: UPnP, found device <http://192.168.1.254:49153/7572534f/gatedesc0b.xml> with private address <192.168.1.100>
Jan 07, 2021 23:26:40.338 [2080] DEBUG - NAT: UPnP, usable device <http://192.168.1.254:49153/7572534f/gatedesc0b.xml> with private address <192.168.1.100>.
Jan 07, 2021 23:26:40.344 [2080] DEBUG - NAT: UPnP, public address is 86.45.178.207
Jan 07, 2021 23:26:40.344 [2080] DEBUG - HTTP requesting GET https://86-45-178-207.a0cfa343d22747969b7723b13009f320.plex.direct:32400/identity
Jan 07, 2021 23:26:40.582 [2020] DEBUG - NetworkServiceBrowser: Parsing SSDP schema for http://192.168.68.101:8008/ssdp/device-desc.xml
Jan 07, 2021 23:26:40.582 [2020] DEBUG - HTTP requesting GET http://192.168.68.101:8008/ssdp/device-desc.xml
Jan 07, 2021 23:26:43.351 [2080] ERROR - Error issuing curl_easy_perform(handle): 28
Jan 07, 2021 23:26:43.351 [2080] DEBUG - HTTP simulating 408 after curl timeout
Jan 07, 2021 23:26:43.351 [2080] DEBUG - MyPlex: mapping state set to 'Mapped - Not Published'.
Jan 07, 2021 23:26:43.360 [2080] DEBUG - MyPlex: Last published value didn't change, we're done.
Jan 07, 2021 23:26:43.796 [15636] ERROR - Error issuing curl_easy_perform(handle): 28
Jan 07, 2021 23:26:43.796 [15636] DEBUG - HTTP simulating 408 after curl timeout
Jan 07, 2021 23:26:43.796 [15620] ERROR - Error issuing curl_easy_perform(handle): 28
Jan 07, 2021 23:26:43.796 [15620] DEBUG - HTTP simulating 408 after curl timeout
Jan 07, 2021 23:26:43.796 [15632] ERROR - Error issuing curl_easy_perform(handle): 28
Jan 07, 2021 23:26:43.796 [15632] DEBUG - HTTP simulating 408 after curl timeout
Jan 07, 2021 23:26:43.797 [0644] DEBUG - HTTP requesting GET https://142-126-142-123.2846010c6226409a90dcda9464ef209f.plex.direct:32400/media/providers
Jan 07, 2021 23:26:44.143 [0644] DEBUG - HTTP 200 response from GET https://142-126-142-123.2846010c6226409a90dcda9464ef209f.plex.direct:32400/media/providers
Jan 07, 2021 23:26:44.143 [0644] ERROR - Unknown metadata type:
Jan 07, 2021 23:26:44.144 [0644] DEBUG - External Metadata: Syncing from media server Spicy Server with 2 existing sections.
Jan 07, 2021 23:26:47.524 [0644] DEBUG - It took 843.750000 ms to retrieve 17849 items.
Jan 07, 2021 23:26:47.565 [0644] DEBUG - External Metadata: Found 3131 items of type artist in our libraries, and a total of 19256 items to look for in 3420 ms.
Jan 07, 2021 23:26:48.105 [0644] DEBUG - It took 359.375000 ms to retrieve 3560 items.
Jan 07, 2021 23:26:48.113 [0644] DEBUG - External Metadata: Found 442 items of type movie in our libraries, and a total of 3560 items to look for in 547 ms.
Jan 07, 2021 23:26:48.113 [0644] DEBUG - HTTP requesting GET https://142-126-142-123.2846010c6226409a90dcda9464ef209f.plex.direct:32400/library/sections/1/all?type=1&excludeFields=summary&excludeElements=Director,Producer,Writer,Role,Genre,Country&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Jan 07, 2021 23:26:48.905 [0644] DEBUG - HTTP 200 response from GET https://142-126-142-123.2846010c6226409a90dcda9464ef209f.plex.direct:32400/library/sections/1/all?type=1&excludeFields=summary&excludeElements=Director,Producer,Writer,Role,Genre,Country&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Jan 07, 2021 23:26:48.912 [0644] DEBUG - External Metadata: Nothing changed, computed diff in 1 ms.
Jan 07, 2021 23:26:49.285 [0644] DEBUG - It took 250.000000 ms to retrieve 200 items.
Jan 07, 2021 23:26:49.285 [0644] DEBUG - External Metadata: Found 22 items of type show in our libraries, and a total of 200 items to look for in 370 ms.
Jan 07, 2021 23:26:49.285 [0644] DEBUG - HTTP requesting GET https://142-126-142-123.2846010c6226409a90dcda9464ef209f.plex.direct:32400/library/sections/4/all?type=2&excludeFields=summary&excludeElements=Director,Producer,Writer,Role,Genre,Country&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Jan 07, 2021 23:26:49.659 [0644] DEBUG - HTTP 200 response from GET https://142-126-142-123.2846010c6226409a90dcda9464ef209f.plex.direct:32400/library/sections/4/all?type=2&excludeFields=summary&excludeElements=Director,Producer,Writer,Role,Genre,Country&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Jan 07, 2021 23:26:49.660 [0644] DEBUG - External Metadata: Nothing changed, computed diff in 0 ms.
Jan 07, 2021 23:26:49.661 [0644] DEBUG - HTTP requesting GET https://plex.vsnet.uk:443/media/providers
Jan 07, 2021 23:26:49.754 [0644] DEBUG - HTTP 200 response from GET https://plex.vsnet.uk:443/media/providers
Jan 07, 2021 23:26:49.754 [0644] ERROR - Unknown metadata type:
Jan 07, 2021 23:26:49.755 [0644] DEBUG - External Metadata: Syncing from media server TITAN with 2 existing sections.
Jan 07, 2021 23:26:49.755 [0644] DEBUG - HTTP requesting GET https://plex.vsnet.uk:443/library/sections/1/all?type=1&excludeFields=summary&excludeElements=Director,Producer,Writer,Role,Genre,Country&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Jan 07, 2021 23:26:50.033 [0644] DEBUG - HTTP 200 response from GET https://plex.vsnet.uk:443/library/sections/1/all?type=1&excludeFields=summary&excludeElements=Director,Producer,Writer,Role,Genre,Country&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Jan 07, 2021 23:26:50.042 [0644] DEBUG - External Metadata: Nothing changed, computed diff in 0 ms.
Jan 07, 2021 23:26:50.044 [0644] DEBUG - HTTP requesting GET https://plex.vsnet.uk:443/library/sections/2/all?type=2&excludeFields=summary&excludeElements=Director,Producer,Writer,Role,Genre,Country&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Jan 07, 2021 23:26:50.174 [0644] DEBUG - HTTP 200 response from GET https://plex.vsnet.uk:443/library/sections/2/all?type=2&excludeFields=summary&excludeElements=Director,Producer,Writer,Role,Genre,Country&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Jan 07, 2021 23:26:50.175 [0644] DEBUG - External Metadata: Nothing changed, computed diff in 0 ms.
Jan 07, 2021 23:26:55.588 [2020] ERROR - Error issuing curl_easy_perform(handle): 28
Jan 07, 2021 23:26:55.588 [2020] DEBUG - HTTP simulating 408 after curl timeout
Jan 07, 2021 23:26:55.588 [2020] ERROR - SSDP: Error parsing device schema for http://192.168.68.101:8008/ssdp/device-desc.xml
Jan 07, 2021 23:26:57.756 [2080] DEBUG - HTTP requesting GET https://plex.tv/api/v2/shared_sources/owned?machineIdentifier=60c11a6674e76aa62faf95edabe05554ed7e9534
Jan 07, 2021 23:26:57.834 [2080] DEBUG - HTTP 200 response from GET https://plex.tv/api/v2/shared_sources/owned?machineIdentifier=60c11a6674e76aa62faf95edabe05554ed7e9534
Jan 07, 2021 23:26:57.867 [2080] DEBUG - HTTP requesting GET https://plex.tv/api/v2/server/access_tokens?auth_token=xxxxxxxxxxxxxxxxxxxx
Jan 07, 2021 23:26:58.009 [2080] DEBUG - HTTP 200 response from GET https://plex.tv/api/v2/server/access_tokens?auth_token=xxxxxxxxxxxxxxxxxxxx
Jan 07, 2021 23:26:58.011 [2080] DEBUG - MyPlex: updating with 16 access tokens
Jan 07, 2021 23:26:58.012 [2064] DEBUG - HTTP requesting GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Jan 07, 2021 23:26:58.012 [2080] DEBUG - HTTP requesting GET https://plex.tv/api/v2/server/users?auth_token=xxxxxxxxxxxxxxxxxxxx
Jan 07, 2021 23:26:58.089 [2080] DEBUG - HTTP 200 response from GET https://plex.tv/api/v2/server/users?auth_token=xxxxxxxxxxxxxxxxxxxx
Jan 07, 2021 23:26:58.091 [2064] DEBUG - HTTP 200 response from GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Jan 07, 2021 23:26:58.092 [2080] DEBUG - HTTP requesting GET https://plex.tv/api/v2/server/users/subscriptions?auth_token=xxxxxxxxxxxxxxxxxxxx
Jan 07, 2021 23:26:58.165 [2080] DEBUG - HTTP 200 response from GET https://plex.tv/api/v2/server/users/subscriptions?auth_token=xxxxxxxxxxxxxxxxxxxx
Jan 07, 2021 23:27:06.747 [12308] DEBUG - Request: [127.0.0.1:62034 (Loopback)] GET /web (2 live) GZIP Signed-in
Jan 07, 2021 23:27:06.750 [11368] DEBUG - Completed: [127.0.0.1:62034] 302 GET /web (2 live) GZIP 3ms 232 bytes (pipelined: 1) -> http://127.0.0.1:32400/web/index.html
Jan 07, 2021 23:27:06.939 [12308] DEBUG - Request: [127.0.0.1:62034 (Loopback)] GET /web/index.html (2 live) GZIP Signed-in
Jan 07, 2021 23:27:06.939 [12308] DEBUG - Final path: "C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-b0c7a97d9\WebClient.bundle\Contents\Resources/index.html"
Jan 07, 2021 23:27:06.939 [12308] ERROR - Couldn't find the file to stream: C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-b0c7a97d9\WebClient.bundle\Contents\Resources/index.html
Jan 07, 2021 23:27:06.941 [11824] DEBUG - Completed: [127.0.0.1:62034] 404 GET /web/index.html (2 live) GZIP 2ms 331 bytes (pipelined: 2)
Jan 07, 2021 23:27:07.724 [12308] DEBUG - Request: [127.0.0.1:62034 (Loopback)] GET /favicon.ico (2 live) GZIP Signed-in
Jan 07, 2021 23:27:07.747 [12308] DEBUG - Content-Length of C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-b0c7a97d9\WebClient.bundle\Contents\Resources\favicon.ico is 5430 (of total: 5430).
Jan 07, 2021 23:27:07.748 [11368] DEBUG - Completed: [127.0.0.1:62034] 200 GET /favicon.ico (2 live) GZIP 23ms 5430 bytes (pipelined: 3)
Jan 07, 2021 23:27:10.407 [2020] DEBUG - NetworkServiceBrowser: Parsing SSDP schema for http://192.168.0.101:8060/
Jan 07, 2021 23:27:10.407 [2020] DEBUG - HTTP requesting GET http://192.168.0.101:8060/
Jan 07, 2021 23:27:25.421 [2020] ERROR - Error issuing curl_easy_perform(handle): 28
Jan 07, 2021 23:27:25.421 [2020] DEBUG - HTTP simulating 408 after curl timeout
Jan 07, 2021 23:27:25.421 [2020] ERROR - SSDP: Error parsing device schema for http://192.168.0.101:8060/
Jan 07, 2021 23:27:25.425 [2020] DEBUG - NetworkServiceBrowser: Parsing SSDP schema for http://192.168.1.254:45514/agent.xml
Jan 07, 2021 23:27:25.425 [2020] DEBUG - HTTP requesting GET http://192.168.1.254:45514/agent.xml
Jan 07, 2021 23:27:25.434 [2020] ERROR - Error issuing curl_easy_perform(handle): 56
Jan 07, 2021 23:27:25.434 [2020] WARN - HTTP error requesting GET http://192.168.1.254:45514/agent.xml (56, Failure when receiving data from the peer) (Recv failure: Connection was reset)
Jan 07, 2021 23:27:25.434 [2020] ERROR - SSDP: Error parsing device schema for http://192.168.1.254:45514/agent.xml
Jan 07, 2021 23:27:25.544 [2020] DEBUG - NetworkServiceBrowser: Parsing SSDP schema for http://192.168.68.115:49154/MediaRenderer/desc.xml
Jan 07, 2021 23:27:25.545 [2020] DEBUG - HTTP requesting GET http://192.168.68.115:49154/MediaRenderer/desc.xml
Jan 07, 2021 23:27:40.559 [2020] ERROR - Error issuing curl_easy_perform(handle): 28
Jan 07, 2021 23:27:40.559 [2020] DEBUG - HTTP simulating 408 after curl timeout
Jan 07, 2021 23:27:40.559 [2020] ERROR - SSDP: Error parsing device schema for http://192.168.68.115:49154/MediaRenderer/desc.xml
Jan 07, 2021 23:28:00.585 [2020] DEBUG - NetworkServiceBrowser: Parsing SSDP schema for http://192.168.1.254:45514/agent.xml
Jan 07, 2021 23:28:00.585 [2020] DEBUG - HTTP requesting GET http://192.168.1.254:45514/agent.xml
Jan 07, 2021 23:28:00.591 [2020] ERROR - Error issuing curl_easy_perform(handle): 56
Jan 07, 2021 23:28:00.591 [2020] WARN - HTTP error requesting GET http://192.168.1.254:45514/agent.xml (56, Failure when receiving data from the peer) (Recv failure: Connection was reset)
Jan 07, 2021 23:28:00.591 [2020] ERROR - SSDP: Error parsing device schema for http://192.168.1.254:45514/agent.xml
Jan 07, 2021 23:28:02.727 [2020] DEBUG - NetworkServiceBrowser: Parsing SSDP schema for http://192.168.1.3:9080
Jan 07, 2021 23:28:02.727 [2020] DEBUG - HTTP requesting GET http://192.168.1.3:9080
Jan 07, 2021 23:28:02.738 [2020] DEBUG - HTTP 200 response from GET http://192.168.1.3:9080
Jan 07, 2021 23:28:02.738 [2020] ERROR - XML: Entity: line 1:
Jan 07, 2021 23:28:02.738 [2020] ERROR - XML: parser
Jan 07, 2021 23:28:02.738 [2020] ERROR - XML: error :
Jan 07, 2021 23:28:02.738 [2020] ERROR - XML: Start tag expected, '<' not found
Jan 07, 2021 23:28:02.738 [2020] ERROR - XML: status=ok
Jan 07, 2021 23:28:02.738 [2020] ERROR - XML: ^
Jan 07, 2021 23:28:02.738 [2020] ERROR - Error parsing content.
Jan 07, 2021 23:28:02.738 [2020] ERROR - Error parsing XML: Error parsing file.
Jan 07, 2021 23:28:02.738 [2020] ERROR - SSDP: Error parsing device schema for http://192.168.1.3:9080
Jan 07, 2021 23:28:10.664 [2020] DEBUG - NetworkServiceBrowser: Parsing SSDP schema for http://192.168.68.101:8008/ssdp/device-desc.xml
Jan 07, 2021 23:28:10.664 [2020] DEBUG - HTTP requesting GET http://192.168.68.101:8008/ssdp/device-desc.xml
Jan 07, 2021 23:28:18.869 [4792] DEBUG - BPQ: [Starting] -> [Processing]
Jan 07, 2021 23:28:18.873 [4792] DEBUG - BPQ: generating queue items from 3 generator(s)
Jan 07, 2021 23:28:18.873 [4792] DEBUG - Sync: skipping sync list 37172465 from device  Blah because it's snoozing
Jan 07, 2021 23:28:18.873 [4792] DEBUG - Sync: updating status for sync list 37172465, sync item 44804667, generator 1947
Jan 07, 2021 23:28:18.873 [4792] ERROR - LPE: unknown item 116609.
Jan 07, 2021 23:28:18.873 [4792] ERROR - Sync: failed to generate query for path library://80d10258-5d6d-49f1-8155-078fc2e64af4/directory/%2Flibrary%2Fmetadata%2F116609%2Fchildren in sync item 44804667
Jan 07, 2021 23:28:18.873 [4792] ERROR - Sync: empty sync set, unable to update status for sync list 37172465, sync item 44804667
Jan 07, 2021 23:28:18.873 [4792] DEBUG - Sync: updating status for sync list 37172465, sync item 44804669, generator 1948
Jan 07, 2021 23:28:18.874 [4792] ERROR - LPE: unknown item 116385.
Jan 07, 2021 23:28:18.874 [4792] ERROR - Sync: failed to generate query for path library://80d10258-5d6d-49f1-8155-078fc2e64af4/directory/%2Flibrary%2Fmetadata%2F116385%2Fchildren in sync item 44804669
Jan 07, 2021 23:28:18.874 [4792] ERROR - Sync: empty sync set, unable to update status for sync list 37172465, sync item 44804669
Jan 07, 2021 23:28:18.874 [4792] DEBUG - Sync: skipping sync list 37172465 from device  Blah because it's snoozing
Jan 07, 2021 23:28:18.874 [4792] DEBUG - Sync: updating status for sync list 37172465, sync item 44804671, generator 1949
Jan 07, 2021 23:28:18.874 [4792] ERROR - LPE: unknown item 116363.
Jan 07, 2021 23:28:18.874 [4792] ERROR - Sync: failed to generate query for path library://80d10258-5d6d-49f1-8155-078fc2e64af4/directory/%2Flibrary%2Fmetadata%2F116363%2Fchildren in sync item 44804671
Jan 07, 2021 23:28:18.874 [4792] ERROR - Sync: empty sync set, unable to update status for sync list 37172465, sync item 44804671
Jan 07, 2021 23:28:18.874 [4792] DEBUG - BPQ: generated 0 item(s) for queue
Jan 07, 2021 23:28:18.874 [4792] DEBUG - PlayQueue: 0 generated IDs compressed down to a 20 byte blob.
Jan 07, 2021 23:28:18.876 [4792] DEBUG - BPQ: [Processing] -> [Idle]
Jan 07, 2021 23:28:25.669 [2020] ERROR - Error issuing curl_easy_perform(handle): 28
Jan 07, 2021 23:28:25.669 [2020] DEBUG - HTTP simulating 408 after curl timeout
Jan 07, 2021 23:28:25.669 [2020] ERROR - SSDP: Error parsing device schema for http://192.168.68.101:8008/ssdp/device-desc.xml
I was able to resolve it by following the steps in this post
thanks @checmk8 :sunglasses: :clap:t2: :clap:t2: :clap:t2:
