Power Outage - Local Linux Server hosting my Plex not connecting
Server Version#:1.41.8.9834-071366d65.x86_64.rpm
Player Version#: 4.147.1
When I start the Linux Server everything comes up. The status of the plex service states:
systemctl status plexmediaserver.service
● plexmediaserver.service - Plex Media Server
   Loaded: loaded (/usr/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: disabled)
   Active: active (running) since Sun 2025-06-15 18:55:10 CDT; 6min ago
  Process: 5697 ExecStartPre=/bin/sh -c /usr/bin/test -d "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" (code=exited, status=0/SUCCESS)
 Main PID: 5702 (Plex Media Serv)
    Tasks: 2
   CGroup: /system.slice/plexmediaserver.service
           └─5702 /usr/lib/plexmediaserver/Plex Media Server
Jun 15 18:55:10 texshow1.wilson.home systemd[1]: Starting Plex Media Server...
Jun 15 18:55:10 texshow1.wilson.home systemd[1]: Started Plex Media Server.
Jun 15 18:55:10 texshow1.wilson.home sh[5702]: Failed to load preferences at /var/lib/plexmediaserver/Library/Application Support/Plex Media Ser...nces.xml
Jun 15 18:55:12 texshow1.wilson.home sh[5702]: Failed to load preferences at /var/lib/plexmediaserver/Library/Application Support/Plex Media Ser...nces.xml
Hint: Some lines were ellipsized, use -l to show in full.
However when I bring up the server frontend… I get the "XXXXXserver.wilson.home is currently unavailable and each reconnect fails. I remember reading something a few years back that this could be related to a back preferences.xml find but I am unsure so I will not tray that.
Any direction would be great!
Tom Wilson
Stop Plex
Look at the file Preferences.xml
Make certain it’s not zero-length and make certain you see your Username and Email – AND – Token is not "" (null)
It is 0 length and there is nothing in the file.
Can this be salvaged? I have added a BUNCH of libraries and movies since the last copy I have
NEVER MIND! I restored my late copy of my Preferences.xml and it is back online. Thank you for seeing that for me!
That works :+1:
I was writing instructions for you
