So I’ve had a bunch of pre-roll videos for a long time and decided to add some more. I typed in all the paths to each video (which is crazy that we don’t have a library or directory we can just point to) and when I hit “Save Changes” it accepted that but then it just deletes the field when you leave the page.
I thought maybe it was a limit on the number of videos but the field wouldn’t really check for that so I guessed that it was a character limitation. I figured out that if you have more than 4094 characters in that field it refuses to save that value.
Is there a way to extend this to unlimited? or create a feature like we all want and make that field point to a library or directory that does the random function automatically?
