Is it possible to set pre-roll to just one library of videos, for example, I have -=Movies=- , -=TV Shows=- and -=Fitness=-, Id like to only have the pre-roll play before the Fitness Videos and to have it play every time the file is watched even if it was watched before by the same user, What I have found when I used pre-rolls before is once a user watches a video with a preroll, if they replay it , it does not play the pre-roll
You can disable the “Enable Cinema Trailers” settings for libraries where you don’t want the pre-roll to play, but you won’t get trailers either. There’s no way to disable the pre-roll only.
that sucks. Thanks for the help
