Since the new design of the preplay screen we can’t see the audio language currently selected. Only the codec is shown whereas the subtitle language is shown…
We have to go the the play settings to see what language is selected.
Could we have the current audio language AND codec displayed directly on preplay screen ?
By the way, on this same screen, being able to click on the cast members to see browse content with the same actor would be also great ! Currently you can select a actor but you can’t click on it…
Just wanted to add this is not an issue only on Android TV. The LG webOS app also only shows the codec/channels for audio now on the pre-play screen in the new (version 5.x.x) app, exactly as o_spring’s screenshots has. The old LG app had the language listed.
