Prevent player controls becoming visible when using volume controls (Mobile)
Hi all, first post
I don’t know if there is a setting for this, but when using the volume controls on my Samsung device, the player controls become visible. It becomes slightly annoying as it takes up a good portion of the screen.
On iPad this does not happen as it just shows a little volume integer in the center of the screen.
Is there a setting to prevent the player controls becoming visible when pressing the volume on the device?
