Private IP manual change
Hi All,
Hoping you can assist me with this. I am currently running PMS on a Synology NAS which has two NICs. One for internal access and the other in a DMZ network for outside access. I recently had to rebuild my firewall at my house, [policy stayed the same], but PMS is picking up the internal IP address as opposed to the external. The NATing and port forwarding are working correctly through my firewall but I cannot seem to force PMS to update its private IP. I have tried disabling the NIC with the internal interface connected to no avail, as well as signed out from all devices, and rebooted. I tried looking to see if there is any sort of xml file of sorts that I can update that information on but was unsuccessful in finding that. Any insight you can offer would be greatly appreciated?
let’s stick with one post to fix your issue…
(duplicate) https://forums.plex.tv/discussion/321240/private-ip-change#latest
