Thanks for the reply "f00b4r"
Log MediaInfo
Geral
Unique ID : 252559812196298454196102289720015822307 (0xBE014021255BC901A70733425C079DE3)
Complete name : E:\Séries\GAME OF THRONES\4 Temporada\Game of Thrones S04E08.mkv
Format : Matroska
Format version : Version 2
File size : 3.58 GiB
Duration : 52mn 21s
Overall bit rate : 9 793 Kbps
Encoded date : UTC 2014-06-02 17:43:01
Writing application : mkvmerge v3.4.0 ('Rapunzel') built on May 15 2010 09:38:20
Writing library : libebml v0.8.0 + libmatroska v0.9.0
Vídeo
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Sim
Format settings, ReFrames : 4 quadros
Codec ID : V_MPEG4/ISO/AVC
Duration : 52mn 21s
Bit rate : 9 022 Kbps
Width : 1 920 pixels
Height : 1 072 pixels
Display aspect ratio : 16:9
Frame rate mode : TConstante
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressivo
Bits/(Pixel*Frame) : 0.183
Stream size : 3.30 GiB (92%)
Writing library : x264 core 142 r2431 ac76440
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=17.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : Inglês
Default : Não
Forced : Não
Matrix coefficients : BT.709
Áudio #1
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 52mn 21s
Bit rate mode : Constante
Bit rate : 192 Kbps
Channel(s) : 2 canais
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 71.9 MiB (2%)
Title : PTBR LODONAS
Language : Português
Default : Não
Forced : Sim
Áudio #2
Format : AC-3
Codec ID : A_AC3
Duration : 52mn 21s
Bit rate : 384 Kbps
Channel(s) : 6 canais
Channel positions : Front: L C R, Side: L R, LFE
Bit depth : 16 bits
Stream size : 144 MiB (4%)
Language : Inglês
Default : Não
Forced : Não
Texto #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : Inglês
Default : Não
Forced : Não
Texto #2
Format : UTF-8
Default : Não
Forced : Não
