hi,
i install plexify and it's good for all the items...like tv shows, i see all the series, but with movies, i see tes films only by letters and not in tes "all movies"...have you an idea where is the problem???
thx
laurent
hi,
thx
laurent
Hard to say if it’s the app or something else not populating the “all movies” tab. That app isn’t being developed as far as I know anymore. I coded a app called openplex in my signature you can check out if you wish, it’s a bit more updated if you can’t get it to work.
thx!
