Problem playing a file that is recording
I have a dreambox at home wich i use to Watch tv, i then have my server with Plex... my workplace restricts me from reaching my dreambox, installing programs and use a vpn. But i can run Plex web, and Watch all my Movies wich is great!
What im trying to do is this,
wget http://dreambox:80001/stream -O livetv.ts
where livetv.ts is located within my Plex library, it shows up in the library and i can start watching it... great but, it the recording is 1min long when starting to play in in plexweb it stops playing after one minute and i then have to restart the 'movie' in Plex, jump to one minute and start watching from where i was..
Have also tried with
ffmpeg -i http://dreambox:8001/stream livetv.mpeg
also works exactly as above.
Plex webapp seems to be sure the Movie only is x min long and then automaticaly stops the stream after that time..
Is there away around this? I noticed the dreambox-plugin but that cant play on plexweb if i understood it right...
With all respect, but you are asking non-developer Q's in a developer area!
Start by going here:
https://forums.plex.tv/topic/96063-support-find-my-plug-in-here-for-support/?p=561709
Locate Popcorn, and ask there
If that doesn't fit, then go here:
https://forums.plex.tv/forum/83-general-chat/
In short, this is NOT a developer question
/T
Oh sorry, just scrolled down in the main forum and found "general" :unsure:
Please remove and ill post again in a better section... sorry
NP, and you have to get in line here for doing that.....And I'm first in that line :D
OP did so.
Find it here:
https://forums.plex.tv/topic/103183-problem-playing-a-file-that-is-recording/#entry607835
Mods/Ninja's: Please lock this one
/T
