Problem to connect
Hi, I got a problem to connect, when I open PlexConnect, the screen shows:
Hi, I got this problem, when I opened PlexConnect the screen shows all this information:
PlexConnect : ***
PlexConnect : PlexConnect
PlexConnect: Press ENTER to shut down.
PlexConnect : ***
Plex Connect: IP_self : 192.168.0.100
PlexGDM: ***
PlexGDM: Looking up Plex Media Server
PlexGDM: ***
PlexGDM: No servers discovered
DNSServer : ***
DNSServer: Starting up.
DNSServer: intercept trailers.apple.com: 192.168.0.100
DNSServer: forward other to higher level DNS: 192.168.0.1
DNSServer: ***
WebServer: ***
WebServer: Servint HTTP on 0.0.0.0 port 80.
The problem is: No servers discovered
This is what I got on settings:
#!/usr/bin/python
Global Settings...
# Plex Media Server
def getPlexGDM():
    return True  # True: use PlexGDM (GoodDayMate) to auto discover PMS
def getIP_PMS():  # default IP, if GDM fails... todo: do we need this fall back?
    return '192.168.178.2'
def getPort_PMS():
    return 32400
# DNS/WebServer
def getIP_DNSmaster():  # Router, ISP's DNS, ...
    return '192.168.0.1'  # google public DNS
def getHostToIntercept():
    return 'trailers.apple.com'
I hope you can help me.
So? Do you have the PMS in reach? Firewall?
I created a rule to python in firewall. What do you mean with PMS?, sorry, I don't know too much about this.
Are you running Plex Media Server (PMS)?
I don't think so... I just followed the steps on the guide, I just open PlexConnect.py, I don't have Plex Media Server.
EDIT
All right, now I got
<span style="font-size:12px;">Plex Media Server 0.9.7.12</span>
Now it says servers discovered: 1
That's the only change presented on the screen, should I be able to run Plex on my Apple TV now? I'm gonna try when I back from work.
Thank you.
