PlexGDM: No servers discovered
i cant find nothing in the trailer app, i get this error : "PlexGDM: No servers discovered"running apple tv 3, with 5.0.2 and mbp with mountain lion.
Router and dns is the same : 192.168.1.1
Settings:
[PlexConnect]
port_pms = 32400
enable_plexgdm = True
ip_dnsmaster = 192.168.1.1
ip_webserver = 0.0.0.0
loglevel = Normal
enable_dnsserver = True
ip_pms = 192.168.178.10
port_webserver = 80
Whats could be wrong ? Thanks.
PlexConnect: started: 16:20:03
PlexConnect: ***
PlexConnect: PlexConnect
PlexConnect: Press ENTER to shut down.
PlexConnect: ***
PlexConnect: IP_self: 192.168.1.6
PlexGDM: ***
PlexGDM: looking up Plex Media Server
PlexGDM: ***
PlexConnect: PMS: 192.168.178.10:32400
DNSServer: started: 16:20:05
DNSServer: ***
DNSServer: Starting up.
DNSServer: intercept trailers.apple.com: 192.168.1.6
DNSServer: forward other to higher level DNS: 192.168.1.1
DNSServer: ***
WebServer: started: 16:20:05
WebServer: ***
WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
WebServer: ***
Settings:
[PlexConnect]
port_pms = 32400
loglevel = Normal
port_webserver = 80
PlexConnect: ***
PlexConnect: ***
PlexGDM: ***
PlexGDM: ***
DNSServer: ***
DNSServer: ***
WebServer: ***
WebServer: ***
manually enter your PMS IP then
ip_pms =
But where i find my ip_pms ?
You do have Plex Media Server running, don't you?
its the IP address fo the machine you are running PMS on.
at Baa: Yes, the Plex Media Server a running, and after i change the ip_pms accordly to my mac, it comes this:
PlexGDM: servers discovered: 1
PlexConnect: PMS: 192.168.1.6:32400
But it still not appear on my atv 3.
Thanks to both.
Thanks to both.
and you've changed the DNS IP on your ATV to be the IP address of the machine running PlexConnect?
Yes, the dns ip is the same.
I have noticed now that when i access to the trailer app, it appears that  the trailers at the moment are not available.
I think its a problem with the plex server, It appears that there is a error conecting to the server.
Captura%20de%20pantalla%202013-06-16%20a
the same as what?
that is nothing to do with PlexConnect.
Try restarting the Plex Media Server and then, once PMS is fully up, restart Plexconnect. That sometimes clears up this sort of issue.
the same as what?
the same where i have download plexconnect (on my mac) from github, i have done all again and now i become this:
WebServer: Failed to connect to HTTP on 0.0.0.0 port 80: [Errno 48] Address already in use
PlexConnect: WebServer not alive. Shutting down.
192:PlexConnect-XML_templates xxxxxx$
