Problem with Naruto (2002) again
Server Version#: 1.26.0.5715
Hi.
When adding Naruto I had a lot of problems so I read forum threads. I split the show into seasons. Everything works well, except the season 1 does NOT show up. All the other seasons appear fine and are sorted fine.
What am I missing?
Thank you!
Folder organization and file names please!
Folder name : Naruto (2002)
Inside there are 5 folders : Season 1 to Season 5
Filename example :
Naruto - S0101 VF-VOSTFR [1080p][X265][10BITS][SR-71]
to
Naruto - S05E41 VF-VOSTFR [1080p][X265][10BITS][SR-71]
Your season 1 files seem to be missing the E prefix for the episode number (s0101s01e01) — unless that’s been a typo
Only the characters inbetween the first pair of square brackets is ignored by Plex.
You want rather something like
Naruto - S0101 [VF-VOSTFR.1080p.X265.10BITS.SR-71]
OMG I can’t believe I missed the E in the file names. Totally worked.
Thank you all <3
That happens, which is why we ask for exact file names. Not the first time, nor last time naming issues will pop up.
