Server Version#: 1.30.1.6483
Player Version#: Web player Version 4.96.2
Hello everyone, I’m having a problem with my plex server. For some reason it started transcoding everything to a very high bitrate, i tried limiting this by going to Quality on plex web and putting Home streaming on 12Mbps, and going to the server settings and setting Limit remote stream bitrate to 12 Mbps. The remove limiting worked, but my home stream is still very high.
I have the setting “Play smaller videos at original quality” but it still tries to upscale everything i watch. Anyone know why?
The original file bitrate for the file im playing now is 1.8 Mbps for example, but it’s scaling it up quite alot.
Please recreate and provide your server logs.
Hello
PS: I have updated to version Version 4.97.3 plex web and Server version Version 1.30.1.6497
Sorry for the late reply. I will attach logs.
17:49 - 17:51 started one series, bitrate between 0-40 Mbps. Average 8Mpbs
17:53 - 17:55 started secound series, birate between 0 - 76 Mbps
- Series one has 8.2 Mbps bitrate
- Series two has 2.7 Mbps bitrate
- Remote stream sais 10Gbps under “now playing”
- Remote access under settings → Remote access → Limit remote stream bitrate was set to maximum.
- Internet Streaming was set to maximum under PLex Web settings
- Play smaller videos at original quality was checked.
Plex Media Server Logs_2023-01-01_17-55-48.zip (78.4 KB)
You do not have debug logging enabled for your server so there isn’t much info to diagnose the issue. Please enable this setting (verbose logging should be off), restart PMS, recreate the issue and grab new logs.
Sorry about that, seems i turned on debug for the player, not the server. Tried watching Akudama drive now, with 8.1mbps orignal bitrate. But server shoots it up to around 30-40 Mbps. I restarted the PMS as requested after enabling debug.
Please feel free to ask anyting else that can aid your troubleshooting. I’m a bit lost at what it can be.
Thanks for the help so far!
Plex Media Server Logs_2023-01-04_20-11-05.zip (340.0 KB)
Ok. PMS is transcoding the video at 20 Mbps. This is because it has to burn in the subtitles, so yes It is bumping up the bitrate. Keep in mind that bitrates are the average. PMS will cap spikes to x2 so yes, you will see spikes in the 30-40 range, but as you see, the average is ~21.
Ok, that explains it. I must have just never noticed that the bitrates go that high during subtitles before. Thanks for the help.
