Problem With Validateprefs()
I am trying to return a MessageContainer with ValidatePrefs(), and each time nothing happens, the log says “(Framework) Request not handled by plug-in”. This is also the case with the starter plugin created by the tool found here: http://dev.plexapp.com/tools/plugin_kickstart/
I’ve included a bit from the log below. It should be noted that I’m using Plex 0.8.3.
Am I doing something wrong? Or is this a known issue?
Thanks!
Nope, that would be a framework bug :slight_smile: Thanks for reporting it! I’ve deployed a fix via the App Store.
