ValidatePrefs()
This function is called when the user modifies their preferences. The developer can check the newly provided values to ensure they are correct (e.g. attempting a login to validate a username and password), and optionally return a MessageContainer to display any error information to the user.
Doesn’t behave as per framework documentation. I have the following installed:
Synology DS1815+ NAS running Plex server app “PlexMediaServer-1.1.4.2757-24ffd60-x86.spk”
Plex Web Version 2.8.1
Plex Server Version 1.1.4.2757
Accessed from running on Windows 10 pro x64
I need it to be working for my Hama agent, as i use agent data folders and if installed with Unsupported Appstore v2, i need to be able to bring a popup with this validation “def ValidatePrefs():” function but while it ran, no popup was shown… So same boat and issue persists…
