problem
I’m getting an error message and can no longer start my home Plex server. As directed, here are my logs. Any help would be appreciated.
You need to work on your titles. “Problem” is not very descriptive of what is actually wrong.
Also you need to include more details about your setup and what error you are seeing. Logs are good, in fact very good, they do not convey all the info that folks need to help you.
Thank you for your time and your comment on my title. Here is a screenshot showing the error message and router type. I hope this helps you help me.
I wish I could help but my comment was intended to help you get help from others. While I am pretty good at sever setup and maintenance I am not the expert you need for this fix.
Also one more thing that the real experts will need is details about your computer and operating system you are using. That may not be needed as the error you are seeing has been discussed several times in the last several months and the fix “could” be quite well known.
My plex is down. Cant get anything. No servers found.
