Problems with modified copy of the lastFM Agent
I tried to create a copy of the lastFM-Agent which can be integrated into the Personal Media Agents. I created a copy of the lastFM bundle and modified the source of the init.py file:
<br />
import lastfm, re<br />
<br />
GOOGLE_JSON = 'http://ajax.googleapis.com/ajax/services/search/web?v=1.0&rsz=large&q=%s+site:last.fm+inurl:music'<br />
BING_JSON   = 'http://api.bing.net/json.aspx?AppId=879000C53DA17EA8DB4CD1B103C00243FD0EFEE8&Version=2.2&Query=%s+site:last.fm&Sources=web&Web.Count=8&JsonType=raw'<br />
<br />
def Start():<br />
  HTTP.CacheTime = CACHE_1WEEK<br />
  <br />
class LastFmAgentArtist(Agent.Artist):<br />
  name = 'Last.fm-Artist'<br />
  languages = [Locale.Language.English, Locale.Language.Korean]<br />
  primary_provider = False<br />
  contributes_to = ['com.plexapp.agents.none']<br />
  <br />
  def search(self, results, media, lang):<br />
    score = 100<br />
     <br />
    for r in lastfm.SearchArtists(String.StripDiacritics(media.artist))[0]:<br />
      id = r[0]<br />
      if id.find('+noredirect') == -1:<br />
        id = r[1]<br />
        id = String.Quote(id.encode('utf-8'))<br />
        Log('id: ' + id + '  name: '+ r[1] + '   score: ' + str(score) + '   thumb: ' + str(r[2]))<br />
        results.Append(MetadataSearchResult(id = id.replace('%2B','%20'), name  = r[1], thumb = r[2], lang  = lang, score = score))<br />
        score = score - 2<br />
    <br />
    # Finally, de-dupe the results.<br />
    toWhack = []<br />
    resultMap = {}<br />
    for result in results:<br />
      if not resultMap.has_key(result.id):<br />
        resultMap[result.id] = True<br />
      else:<br />
        toWhack.append(result)<br />
...<br />
The newly created agent appears in the correct section but unfortunately it collects only strange informations: regardless which album will be scanned I get only artistinfo about an band called "Sixpence none the richer". I took a look at the logs and I guess the problem is with the media.artists data:
<br />
2011-04-15 19:43:58,642 (-5f3cfac0) :  DEBUG (core) - Loading plug-in code<br />
2011-04-15 19:43:59,277 (-5f3cfac0) :  DEBUG (agentkit) - Creating new agent class called LastFmAgentArtist<br />
2011-04-15 19:43:59,277 (-5f3cfac0) :  DEBUG (agentkit) - Updating agent information: [{'media_types': ['Artist'], 'accepts_from': None, 'fallback_agent': None, 'contributes_to': ['com.plexapp.agents.none'], 'languages': ['en', 'ko'], 'primary_provider': False, 'prefs': False, 'name': 'Last.fm-Artist'}]<br />
2011-04-15 19:43:59,279 (-5f3cfac0) :  DEBUG (core) - Requesting http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0FnZW50U2VydmljZTpVcGRhdGVJbmZv/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQo2CmRpY3QKbGlzdApkaWN0Cmxpc3QKbGlzdApsaXN0CjIKczMyCmNvbS5wbGV4YXBwLmFnZW50cy5sYXN0Zm0tYXJ0aXN0czEwCmlkZW50aWZpZXJyMQpzMTAKYWdlbnRfaW5mbzEKcjIKOApyMwpzMTEKbWVkaWFfdHlwZXNuczEyCmFjY2VwdHNfZnJvbW5zMTQKZmFsbGJhY2tfYWdlbnRyNApzMTQKY29udHJpYnV0ZXNfdG9yNQpzOQpsYW5ndWFnZXNiMHMxNgpwcmltYXJ5X3Byb3ZpZGVyYjBzNQpwcmVmc3MxNApMYXN0LmZtLUFydGlzdHM0Cm5hbWUxCnM2CkFydGlzdDEKczIzCmNvbS5wbGV4YXBwLmFnZW50cy5ub25lMgpzMgplbnMyCmtvcjAK<br />
2011-04-15 19:43:59,296 (-5f3cfac0) :  DEBUG (agentkit) - Creating new agent class called LastFmAlbumAgent<br />
2011-04-15 19:43:59,297 (-5f3cfac0) :  DEBUG (agentkit) - Updating agent information: [{'media_types': ['Artist'], 'accepts_from': None, 'fallback_agent': None, 'contributes_to': ['com.plexapp.agents.none'], 'languages': ['en', 'ko'], 'primary_provider': False, 'prefs': False, 'name': 'Last.fm-Artist'}, {'media_types': ['Album'], 'accepts_from': None, 'fallback_agent': 'com.plexapp.agents.allmusic', 'contributes_to': None, 'languages': ['en'], 'primary_provider': True, 'prefs': False, 'name': 'Last.fm'}]<br />
2011-04-15 19:43:59,299 (-5f3cfac0) :  DEBUG (core) - Requesting http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0FnZW50U2VydmljZTpVcGRhdGVJbmZv/Y2VyZWFsMQoxCmxpc3QKMApyMAo_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<br />
2011-04-15 19:43:59,315 (-5f3cfac0) :  DEBUG (core) - Running pre-flight checks<br />
2011-04-15 19:43:59,317 (-5f3cfac0) :  INFO (core) - Started plug-in<br />
2011-04-15 19:43:59,317 (-5f3cfac0) :  DEBUG (socketinterface) - Starting socket server<br />
2011-04-15 19:43:59,321 (-5f3cfac0) :  DEBUG (core) - Created a thread named 'start'<br />
2011-04-15 19:43:59,322 (-5f3cfac0) :  INFO (socketinterface) - Socket server started on port 50121<br />
2011-04-15 19:43:59,323 (-5f3cfac0) :  INFO (pipeinterface) - Entering run loop<br />
2011-04-15 19:43:59,326 (-5f3cfac0) :  DEBUG (core) - Handling request GET /:/prefixes<br />
2011-04-15 19:43:59,328 (-5f3cfac0) :  DEBUG (core) - Response: 200<br />
2011-04-15 19:43:59,337 (-4f9e9000) :  DEBUG (core) - Handling request GET /:/plugins/com.plexapp.agents.lastfm-artist/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo0CnMyCnhuczQKbGFuZ3M2CkFydGlzdHMxMAptZWRpYV90eXBlYjBzNgptYW51YWxyMQpzNgprd2FyZ3MzCnMzNQpjb20ucGxleGFwcC5hZ2VudHMubm9uZTovLzE%40bGFuZz14bnM0Cmd1aWRiMXM1CmZvcmNlczIzCmNvbS5wbGV4YXBwLmFnZW50cy5ub25lczEzCnByaW1hcnlfYWdlbnRyMAo_<br />
2011-04-15 19:43:59,338 (-4f9e9000) :  INFO (agentkit) - Searching for matches for {'guid': 'com.plexapp.agents.none://1?lang=xn', 'force': True, 'primary_agent': 'com.plexapp.agents.none'}<br />
2011-04-15 19:43:59,339 (-4f9e9000) :  DEBUG (accessor) - Creating a new read-only model access point for provider com.plexapp.agents.none in namespace 'metadata'<br />
2011-04-15 19:43:59,339 (-4f9e9000) :  DEBUG (classes) - Generating class for 'Album' model in namespace 'metadata' with access point 'com.plexapp.agents.none'<br />
2011-04-15 19:43:59,340 (-4f9e9000) :  DEBUG (classes) - Generating class for 'Episode' model in namespace 'metadata' with access point 'com.plexapp.agents.none'<br />
2011-04-15 19:43:59,340 (-4f9e9000) :  DEBUG (classes) - Generating class for 'TV_Show' model in namespace 'metadata' with access point 'com.plexapp.agents.none'<br />
2011-04-15 19:43:59,341 (-4f9e9000) :  DEBUG (classes) - Generating class for 'Artist' model in namespace 'metadata' with access point 'com.plexapp.agents.none'<br />
2011-04-15 19:43:59,342 (-4f9e9000) :  DEBUG (classes) - Generating class for 'Track' model in namespace 'metadata' with access point 'com.plexapp.agents.none'<br />
2011-04-15 19:43:59,342 (-4f9e9000) :  DEBUG (classes) - Generating class for 'Movie' model in namespace 'metadata' with access point 'com.plexapp.agents.none'<br />
2011-04-15 19:43:59,343 (-4f9e9000) :  DEBUG (classes) - Generating class for 'VideoClip' model in namespace 'metadata' with access point 'com.plexapp.agents.none'<br />
2011-04-15 19:43:59,343 (-4f9e9000) :  DEBUG (classes) - Generating class for 'Person' model in namespace 'metadata' with access point 'com.plexapp.agents.none'<br />
2011-04-15 19:43:59,344 (-4f9e9000) :  DEBUG (classes) - Generating class for 'Role' model in namespace 'metadata' with access point 'com.plexapp.agents.none'<br />
2011-04-15 19:43:59,344 (-4f9e9000) :  DEBUG (classes) - Generating class for 'Season' model in namespace 'metadata' with access point 'com.plexapp.agents.none'<br />
2011-04-15 19:43:59,345 (-4f9e9000) :  DEBUG (model) - Loading model with GUID com.plexapp.agents.none://1?lang=xn<br />
2011-04-15 19:43:59,349 (-4f9e9000) :  DEBUG (model) - Deserializing from /Users/gkoeder/Library/Application Support/Plex Media Server/Metadata/Artists/c/233aadf8c9a61f5e6851ca59458dc69c6c68eee.bundle/Contents/com.plexapp.agents.none/Info.xml<br />
2011-04-15 19:43:59,363 (-4f9e9000) :  DEBUG (core) - Fetching http://ws.audioscrobbler.com/2.0/?method=artist.search&artist=None&page=0&api_key=d5310352469c2631e5976d0f4a599773 from the HTTP cache<br />
2011-04-15 19:43:59,380 (-4f9e9000) :  INFO (core) - id: Sixpence%20None%20the%20Richer  name: Sixpence None the Richer   score: 100   thumb: http://userserve-ak.last.fm/serve/252/565723.jpg<br />
2011-04-15 19:43:59,380 (-4f9e9000) :  INFO (core) - id: None%20More%20Black  name: None More Black   score: 98   thumb: http://userserve-ak.last.fm/serve/252/314341.jpg<br />
2011-04-15 19:43:59,381 (-4f9e9000) :  INFO (core) - id: 2nd%20II%20None  name: 2nd II None   score: 96   thumb: http://userserve-ak.last.fm/serve/252/17008511.jpg<br />
2011-04-15 19:43:59,381 (-4f9e9000) :  INFO (core) - id: And%20Then%20There%20Were%20None  name: And Then There Were None   score: 94   thumb: http://userserve-ak.last.fm/serve/252/50419569.jpg<br />
2011-04-15 19:43:59,381 (-4f9e9000) :  INFO (core) - id: Xe-NONE  name: Xe-NONE   score: 92   thumb: http://userserve-ak.last.fm/serve/252/53116047.jpg<br />
2011-04-15 19:43:59,382 (-4f9e9000) :  INFO (core) - id: none  name: none   score: 90   thumb: http://userserve-ak.last.fm/serve/252/10897657.jpg<br />
2011-04-15 19:43:59,382 (-4f9e9000) :  INFO (core) - id: Apologies%2C%20I%20Have%20None  name: Apologies, I Have None   score: 88   thumb: http://userserve-ak.last.fm/serve/252/42957457.jpg<br />
2011-04-15 19:43:59,383 (-4f9e9000) :  INFO (core) - id: And%20None%20of%20Them%20Knew%20They%20Were%20Robots  name: And None of Them Knew They Were Robots   score: 86   thumb: http://userserve-ak.last.fm/serve/252/218364.jpg<br />
2011-04-15 19:43:59,383 (-4f9e9000) :  INFO (core) - id: Sixpence%20None%20the%20Richer%20and%20Jars%20of%20Clay  name: Sixpence None the Richer and Jars of Clay   score: 84   thumb: http://userserve-ak.last.fm/serve/252/49256771.jpg<br />
2011-04-15 19:43:59,384 (-4f9e9000) :  INFO (core) - id: None%20Shall%20Be%20Saved  name: None Shall Be Saved   score: 82   thumb: http://userserve-ak.last.fm/serve/252/4804.jpg<br />
2011-04-15 19:43:59,384 (-4f9e9000) :  INFO (core) - id: Lose%20None  name: Lose None   score: 80   thumb: http://userserve-ak.last.fm/serve/252/2621953.jpg<br />
2011-04-15 19:43:59,385 (-4f9e9000) :  INFO (core) - id: None%20Other  name: None Other   score: 78   thumb: http://userserve-ak.last.fm/serve/252/2506761.jpg<br />
2011-04-15 19:43:59,385 (-4f9e9000) :  INFO (core) - id: None%20of%20the%20Above  name: None of the Above   score: 76   thumb: http://userserve-ak.last.fm/serve/252/49291607.jpg<br />
2011-04-15 19:43:59,385 (-4f9e9000) :  INFO (core) - id: Sixpence%20None%20The%20Richer%20%28Holiday%29  name: Sixpence None The Richer (Holiday)   score: 74   thumb: http://userserve-ak.last.fm/serve/252/56222333.png<br />
2011-04-15 19:43:59,386 (-4f9e9000) :  INFO (core) - id: Second%20To%20None  name: Second To None   score: 72   thumb: http://userserve-ak.last.fm/serve/252/3556193.jpg<br />
2011-04-15 19:43:59,386 (-4f9e9000) :  INFO (core) - id: None%20Left%20Standing  name: None Left Standing   score: 70   thumb: http://userserve-ak.last.fm/serve/252/396293.jpg<br />
2011-04-15 19:43:59,387 (-4f9e9000) :  INFO (core) - id: None%20Nedelkovska  name: None Nedelkovska   score: 68   thumb: http://userserve-ak.last.fm/serve/252/22434183.jpg<br />
2011-04-15 19:43:59,387 (-4f9e9000) :  INFO (core) - id: %28none%29  name: (none)   score: 66   thumb: None<br />
2011-04-15 19:43:59,388 (-4f9e9000) :  INFO (core) - id: Format%20None  name: Format None   score: 64   thumb: http://userserve-ak.last.fm/serve/252/40526701.jpg<br />
2011-04-15 19:43:59,388 (-4f9e9000) :  INFO (core) - id: none%20the%20less  name: none the less   score: 62   thumb: http://userserve-ak.last.fm/serve/252/5431731.jpg<br />
2011-04-15 19:43:59,388 (-4f9e9000) :  INFO (core) - id: Sixpence%20None%20the%20Richer%20and%20Bebo%20Norman  name: Sixpence None the Richer and Bebo Norman   score: 60   thumb: None<br />
2011-04-15 19:43:59,389 (-4f9e9000) :  INFO (core) - id: God.Fear.None  name: God.Fear.None   score: 58   thumb: http://userserve-ak.last.fm/serve/252/7907095.jpg<br />
2011-04-15 19:43:59,389 (-4f9e9000) :  INFO (core) - id: DJ%20Quik%20featuring%20Snoop%20Dogg%2C%20Nate%20Dogg%2C%20AMG%2C%202nd%20II%20None%2C%20Hi-C%20%26%20El%20DeBarge  name: DJ Quik featuring Snoop Dogg, Nate Dogg, AMG, 2nd II None, Hi-C & El DeBarge   score: 56   thumb: None<br />
2011-04-15 19:43:59,390 (-4f9e9000) :  INFO (core) - id: Company%20of%20None  name: Company of None   score: 54   thumb: None<br />
2011-04-15 19:43:59,390 (-4f9e9000) :  INFO (core) - id: 2nd2none  name: 2nd2none   score: 52   thumb: http://userserve-ak.last.fm/serve/252/59438049.jpg<br />
2011-04-15 19:43:59,390 (-4f9e9000) :  INFO (core) - id: %3CNone%3E  name: <None>   score: 50   thumb: None<br />
2011-04-15 19:43:59,391 (-4f9e9000) :  INFO (core) - id: Leigh%20Nash%20of%20Sixpence%20None%20the%20Richer  name: Leigh Nash of Sixpence None the Richer   score: 48   thumb: None<br />
2011-04-15 19:43:59,391 (-4f9e9000) :  INFO (core) - id: %5BNone%5D  name: [None]   score: 46   thumb: None<br />
2011-04-15 19:43:59,392 (-4f9e9000) :  INFO (core) - id: -none-  name: -none-   score: 44   thumb: None<br />
2011-04-15 19:43:59,392 (-4f9e9000) :  INFO (core) - id: Hybrid%20None  name: Hybrid None   score: 42   thumb: http://userserve-ak.last.fm/serve/252/44319217.jpg<br />
2011-04-15 19:43:59,406 (-4f9e9000) :  DEBUG (core) - Response: 200<br />
The log above was created while searching for artistinfo about Metallica. I looks like media.artist contains "none" or something like that. Since I didn't modify the code to collect data I'm wondering why media.artist contains in this case a false string while the same code in the original lastFM-agent works fine.
Anyone has an idea whats going wrong?
Thanks!
I don’t have any solution. Just to add me to the problem that you are having.
