Problems with Plex Media Server 0.9.14.4/Unraid/Rasplex
Folks,
Upgrading my unraid server to the latest Plex Plus Release y’day (0.9.14.4) and now when viewing on Pi2 B via Rasplex it seems buggy. Thumbnails for a lot of the shows don’t load, some playback shuttering and all the settings seem to have gone i.e. screen calibration, timezone, audio settings etc… Even whenever I fix these and restart the settings don’t seem to stay. I am using version 0.7.0. Was going to upgrade to version 1.0.1 but not sure if that is the best idea until I troubleshoot this. Anyone else had any problems with the latest PMS? Worth rolling back to 0.9.14.3?
Thanks!
@Starfoxy said:
Folks,
Thanks!
Rasplex 1.0.1 works fine with 0.9.14.4 on RPi B, B+, 2 and Zero, change your update channel to Pre-release and update or use GetRasplex to flash latest release to your SD Card, see here Install Rasplex using GetRasPlex for OSX or Windows GUI · RasPlex/RasPlex Wiki · GitHub
Regards
Thanks Ned for the prompt response. Will get trying out this upgrade at the weekend - definitely going to have to remove the SD card and use GetRasplex as the other method doesn’t seem to be working for me. Hopefully that solves the database issues.
