Program guide shows CBS as a different listing
As the title says, the program guide is showing the listings for another channel (KJWPDT or METTV) but when i select the channel to view I get CBS as i should. I’ve tried removing and adding the tuner over and over again but still got the same result. Channel scans or running the programming guide update didn’t help either. Anyone else experience this? Is there a fix?
Running Version 1.10.1.4561 on Windows 10. I’m not sure what version this issue started with but it’s been doing this for close to a month, maybe a little more.
Yes. I’m having the same exact issue. Did you find any solution?
There is an option when you set up your DVR/Tuner to select which stations are displayed, and which aren’t. This is also the area to double check that the correct station for guide data is selected.
Settings > Server > Live TV & DVR
Click the portion in your tuner area that says XX Channels - XX Enabled
This should allow you to double check and make sure the correct station is selected. This is how Plex knows what guide data to pull.
As depicted here:
Thank for your response. I already did that but no luck still shows wrong listing. Is there a way to manually override the mapping/listing?
