ChuckPa
October 16, 2018, 10:08pm
21
That CPU doesn’t have QSV support (no HW transcoding).
14,000 passmarks will get you about 10 Mbps of HEVC decoding. (it’s that hard of a codec)
Intel® Xeon® Processor E5-2470 v2 (25M Cache, 2.40 GHz) quick reference guide including specifications, features, pricing, compatibility, design documentation, ordering codes, spec codes and more.
https://www.cpubenchmark.net/cpu.php?cpu=Intel+Xeon+E5-2470+v2+%40+2.40GHz&id=2715
Plex support is solid for QSV and those processors with ample CPU. Neither are present in this case.
It make sense. So, out of the I7 line up, what is the the that can support it, and what is recommended? Or can also an AMD can do. I need to do my budget.
Is the I7 5000 series has QSV?
ChuckPa
October 17, 2018, 11:26pm
23
The last 4 digits (Xxxx
part) tell you which series (Cantiga is 0xxx,
Skylake = 6xxx)
Intel® Quick Sync Video is Intel's brand for its dedicated video encoding and decoding hardware core. Quick Sync was introduced with the Sandy Bridge CPU microarchitecture on 9 January 2011, and has been found on the die of Intel products ever since.
The name "Quick Sync" refers to the use case of quickly transcoding ("converting") a video from, for example, a DVD or Blu-ray Disc to a format appropriate to, for example, a smartphone.
Unlike video encoding on a CPU or a general-purpose GPU, Quic...
system
Closed
January 15, 2019, 11:33pm
24
