Hi all,
So when playing back via PS3 I keep getting the progress/seek bar popping up for a couple of seconds. Was happening approx every 5 mins and last night was every 10 mins exactly to the second. I have disabled screensavers on the PS3 and tried hiding the controller at the other end of the house to see if it was sending an intermittent signal but still happens. Any ideas?
Server Version#:1.19.1.2645
Player Version#: 3.1.0
I would say ps3 plex app is basically dead at this point (its no longer supported/updated). It will more than likely be difficult to watch anything on it. I suggest moving to a new/still supported device.
Yeah fair call. Hopefully it hangs in there a bit longer. Son’s PS4 will get moved onto that room upon PS5 release. If not I’ll sort out an android box of some sort.
