PS5 Buffering constantly ever 5 sec. No playback possible on remote server
Server Version#: 1.32.5.7349
Player Version#:latest
Its completely useless . Buffers every video from remote . While the same and all videos plays fine with apple TV or Fire tv stick 4k and normal stick.
Remote server can play any 1080P and 4k files direct stream.
Its not about bandwidth issue as i have 200Mbps and files are mere 2-10gb
Need series focus on fixing the broken app or gives us a guide to what will support for direct play both video and Audio and what will require trans code for video and Audio. And best possible settings for both local server and remote server.
PS4 update is doing this same thing too. A work around is to de-select “direct play” in the global settings forcing it to do “direct stream” or full transcode. Not the best option in my opinion. I put a message out to the PS4 update employee but I have not heard back yet. Must be something they did, and future update will hopefully fix. But wish I would see an acknowledgment back from staff. Good luck.
