PVR
is there a way to get the PVR feature on my plex even tought my tuner don’t emit signals and is wire connected? “not coax cable”
What tuner do you have?
I think you mean you are getting IPTV streams… not sure though as your post says almost nothing.
If yes, IPTV. Then I believe you need a Plex channel capable of displaying the IPTV streams.
Search the forums for that then.
If the answer is no. Not IPTV, then more information is needed.
ah. sorry. its a Motorola VIP1003. and since it only got a ethernet connector then i will belive its IPTV
