Hello,
Could a Plex team member please reset the certificate/CSR state for my Plex Media Server?
Platform: QNAP, native Plex QPKG manually installed from the Plex website
Plex Media Server version: 1.43.3.10828-00f62d37d
Secure Connections: Preferred
Strict TLS configuration: Disabled
Server status: Claimed and signed in
Remote Access: Fully accessible outside my network
Clients that permit insecure connections can access the server, but clients that require secure connections report it as unavailable.
The active Plex data directory does not contain Cache/cert-v2.p12.
When Plex starts or when Remote Access is disabled and re-enabled, the certificate request fails with:
CERT: Certificate did not exist, fetching a new one.
HTTP 200 response from GET /certificate/subject
HTTP 429 response from PUT /certificate/csr?reason=missing&invalidIn=0
CERT: Error acquiring new certificate: Failed to upload CSR: 429
API rate limit exceeded
I have already:
verified the QNAP system time and NTP synchronization;
changed my Plex account password;
signed out all connected devices;
enabled two-factor authentication;
reclaimed the server;
confirmed that the server is claimed and authenticated;
confirmed that Plex can communicate with
servers.plex.tv; -
confirmed that no custom certificate is configured;
disabled and re-enabled Remote Access;
confirmed that port forwarding and direct remote access are working;
confirmed that no certificate is currently presented on port 32400.
I can provide additional logs or server details privately if required.
Could you please reset the certificate/CSR state for this server on the Plex backend?
Thank you.
